Old 07-10-2014, 02:50 PM   #1
BigCarl
Difference: Blazer/Jimmy vs Short Box Frame
Is there are difference between a 2wd Short Box Frame and 2wd Blazer frame.
I know the fuel tank is in a different spot, but what about bolt holes, cross members.
Specifically, could you take a Blazer with a rotted frame and swap the body to a short box frame without cutting, welding, fabricating, etc?
BigCarl is offline   Reply With Quote
Old 07-10-2014, 02:59 PM   #2
A1971Blazer
A1971Blazer's Avatar
Re: Difference: Blazer/Jimmy vs Short Box Frame
I think they are a different wheelbase
A1971Blazer is offline   Reply With Quote
Old 07-10-2014, 03:02 PM   #3
chuckmc8
It's alsways something.....
chuckmc8's Avatar
SWB truck is 9" longer than a Blazer frame and Blazer has different (or additional) body mounts
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 07-11-2014, 01:05 PM   #4
smbrouss70
smbrouss70's Avatar
Wheelbase difference is 11". 104" for the Blazer, 115" for the truck. I was planning to shorten a truck frame and swap the body mount brackets to make a 2wd Blazer frame before I found my 2wd Blazer. There is another member on here that did it, and he told me that all it took was careful measurements to get the body mounts in the right place.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-12-2014, 02:56 PM   #5
Horatio
I kinda have a similar question. I have a 72 Blazer with a really rusty body and a 71 SWB step-side in decent condition. Can I drive the Blazer until it falls apart then swap the 4x4 drive-train over to the SWB?
Horatio is offline   Reply With Quote
Old 07-12-2014, 06:40 PM   #6
A1971Blazer
Any swap is possible........depends on how much you have of these things:
1. Money....you can save it up.
2. Time.......you can't save it up.
3. Know-how......you can learn
4. Tools........>?
Old 07-18-2014, 09:39 AM   #7
BigCarl
4. Tools........>?
This was initially my though. I have a 2wd short box frame and short stepside box and a 4wd Blazer. What I was thinking was just using the 4wd Blazer frame for the stepside and using the 2wd short frame for the Blazer.
That being said, I don't really feel like cutting up a perfectly good shortbox frame and adding on to a perfectly good blazer frame.
Old 07-18-2014, 09:42 AM   #8
BigCarl
One more question regarding frames.
I have a 72 4wd blazer, but someone has hacked up the crossmember under the engine to make room for a 454. Are the 67-72 4wd truck crossmembers under the engine the same one as in a Blazer?
Ultimately, I would like to pull the 454 and use it for another project and replace it with a 350 TBI like my 72 GMC Longbox.
Old 07-19-2014, 03:09 PM   #9
BigCarl
Bump for asking if 4wd truck and 4wd blazers use the same engine cradle/cross member?
Thread Tools
Display Modes
