Old 07-11-2014, 05:15 PM   #1
jrigheimer
jrigheimer's Avatar
Spindle removal: what I am I doing wrong?
I can get the spindle off. I have a pickle fork and a hammer nothing is working. The drum brake is welded to the spindle so I don't have much room.
jrigheimer is offline   Reply With Quote
Old 07-11-2014, 05:16 PM   #2
jrigheimer
jrigheimer's Avatar
Re: Spindle removal: what I am I doing wrong?
Bkmm
Old 07-11-2014, 05:26 PM   #3
jrigheimer
jrigheimer's Avatar
Pickle fork is all the way in?
Old 07-11-2014, 05:30 PM   #4
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
I hate to say this but first of all its going to be super difficult to get that spindle out at the lower because the drum backing plate wont let it drop far enough. Secondly if I have a stuck balljoint I make sure the nut has enough threads on the balljoint to keep it contained and I turn the wheel just like you have it and pop the spindle right at the ball joint with a 2lb hammer however this does leave marks on the spindle so if you're not swapping you're best to keep working with the fork.
Oldtruckfanatic is offline   Reply With Quote
Old 07-11-2014, 05:32 PM   #5
Oldtruckfanatic
Truck junkie
Also turn that fork 90 degrees its nowhere near all the way in you want to point it so its not going to hit the backing plate. The idea is to shock it to release the taper so it sometimes it takes a pretty good whack its not like driving a nail.
Old 07-11-2014, 05:36 PM   #6
bonnieclyde100
what type of hammer are you using? sometimes a regular nail hammer doesnt build enough torque to knock them loose its better if you use a small sledge hammer one that is just a little bigger than a nail because they are heavier and create more torque. also sometimes hitting the spindle on the thick part that wraps around the ball joints that sometimes will knock them loose
bonnieclyde100 is offline   Reply With Quote
Old 07-11-2014, 05:46 PM   #7
jrigheimer
jrigheimer's Avatar
I just have a nail hammer the ball joint is almost completely eroded
Old 07-11-2014, 05:47 PM   #8
jrigheimer
jrigheimer's Avatar
What pound hammer do I need
Old 07-11-2014, 05:49 PM   #9
Oldtruckfanatic
Truck junkie
Use a small 2lb single or double jack sledge hammer
Old 07-11-2014, 05:53 PM   #10
jrigheimer
jrigheimer's Avatar
Should I keep trying with the pickle for
Old 07-11-2014, 06:02 PM   #11
Oldtruckfanatic
Truck junkie
If you use a heavier hammer the fork will work fine. You really do need to take off that backing plate though. Even when you get it unseated it wont come off the ball joint because of the recess the end of the control arm is in. I have tried it before.
Old 07-11-2014, 06:04 PM   #12
jrigheimer
jrigheimer's Avatar
how to i take it off, it looks like its welded to the spindle itself. the bolts are removed and I've tried prying it off but it does move at all
Old 07-11-2014, 06:57 PM   #13
3drburb
With the truck supported you will need a very big hammer to hit the spindle right at the lower part where the bolt goes thru it. If it is welded, grind the weld off and then give it a few good hits until it comes loose. Btw you will not need the pickle fork for this.
You may need to find a hammer like this if yours dont work.
3drburb is offline   Reply With Quote
Old 07-11-2014, 06:58 PM   #14
jrigheimer
jrigheimer's Avatar
The hammer worked. But still can't get the upper off
Old 07-11-2014, 07:03 PM   #15
3drburb
Secure your brake line, then use the fork on the upper or do whatever you did to free up the lower.
Old 07-11-2014, 07:05 PM   #16
jrigheimer
jrigheimer's Avatar
It just took some more effort haha, that's for the help
Old 07-11-2014, 07:05 PM   #17
Oldtruckfanatic
Truck junkie
The upper will do the same just keep at it. Also the reason the backing plate wouldn't come off is that the pin at the top center of the plate that the shoes and springs are hooked to is a big bolt that goes through the plate into the spindle. I'm glad you got it off I haven't been able to do it without beating up the backing plate or removing it.
Old 07-11-2014, 07:06 PM   #18
Oldtruckfanatic
Truck junkie
Oops too late. Good job.
Old 07-11-2014, 07:25 PM   #19
jrigheimer
jrigheimer's Avatar
Talking Re: Spindle removal: what I am I doing wrong?
Thanks for all the help
Thread Tools
Display Modes
