07-12-2014, 03:08 PM | #1 |
4 speed transmission - 69 GMC
Anyone know the best alternative to the original 4 speed non syncro transmission bull low. Would prefer to keep factory bell housing
07-12-2014, 03:15 PM | #2 |
Re: 4 speed transmission - 69 GMC
What is the end result that you want? How much do you want to spend? What do you use your truck for?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
07-12-2014, 04:09 PM | #3 |
Want to do as cost effective as possible. My 350 just seems to be wasted by the transmission. If I could re- gear the transmission, and up the rear ratio to take advantage of the horsepower and the transmission. Like to keep expenses down. I am a mechanic by trade and just want my options.
07-12-2014, 04:12 PM | #4 |
And I also want to try to keep my survivor looking original. No adding cross members and such.
07-12-2014, 04:52 PM | #5 |
I would keep the Trans, in my opinion. The Granny Gear 1st is great for off-road and starting off with a good load on it. Of course, I would even use 1st when empty, lol.
Changing the Rear to a Higher Gear would really make the biggest difference. Unless you would go to an Over-Drive Trans, it would still be the same at 1 to 1 in the last gear. Bill
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
07-12-2014, 06:14 PM | #6 |
07-12-2014, 06:19 PM | #7 |
Overdrive would be great, but all research I have seen says that overdrive conversions would require housing replacement, and adding a tenant cross member and usually the shifter does not come through the floor in the original location
07-12-2014, 06:22 PM | #8 |
07-12-2014, 07:11 PM | #9 | |
I went the easy route with my '72 C-10 and bought some taller tires. It seem to knock my gears from a 3.73 to about a 3.63, which made a size-able difference. Bill
07-13-2014, 12:58 AM | #10 |
I think that the granny low gear setup has the same top three as others, and believe that a trans end-geared significantly different than yours would be pricey. I agree with whomever said better to change the rear gear ratio. I have a similar situation with one truck and am getting ready to install a Brown-Lipe over/under unit - have to build an added support and shorten one driveshaft - but still am going to try it.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
07-13-2014, 12:41 PM | #11 |
I would love to go with a Brown-Lipe over/under unit in some of my trucks.
The hardest part seems to be finding one. Bill
Thread Tools | |
Display Modes | |
