Old 07-15-2014, 08:34 AM   #1
East Tex
TBSS VS. Doug Thorley
I bought a pair of used TBSS exhaust manifolds last year when I was gathering parts for my swap. Both heat shields are dented, cracked, and scratched up. Also all the studs are trashed. I got out my torch and removed the old studs and I have new replacements on hand. But now I am thinking if these will look nice when installed, or maybe I need to just go and buy Doug Thorley THY-324Y-C headers. I thought about buying new heat shields for these old manifolds ($52), but the manifolds will still be rusty and not that nice looking. So then I thought I'll Jet Hot coat these manifolds and not buy heat shields.
Whatever I run, I want it to look nice. I know the headers are expensive but they look nice. I haven't ran headers in many years, but I remember replacing collector flange gaskets all the time. Are today's headers and gaskets better?
With all that said, I'm looking for opinions on manifolds VS headers, Jet Hot coating, and all the above.
My 1972 K5 6.0 LTR 4L60 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=622068
East Tex is offline   Reply With Quote
Old 07-16-2014, 05:03 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: TBSS VS. Doug Thorley
I found a local powder coating shop that does a ceramic coating in black. I have 2010 Camaro LS3 stock manifolds and will have them coated along with my Y pipe (2 into 1 exhaust) It will be cheaper then JetHot, but I have no real experience with the longevity of the coating. I decided against headers becasue of the possible gasket issuses, I want the truck to be quiet and the motor is stock anyway. The camaro manifolds are 2.5" at the collector and I have a Y collector going into a large 3" muffler with a single outlet on the passenger side in front of the rear wheel.
Rich
1972 K5 Blazer CST Click HERE
Old 07-16-2014, 07:28 AM   #3
East Tex
I never thought to ask my local powder coater if he does high temp coatings.
Old 07-23-2014, 08:11 AM   #4
jamesjones
Freakin Awesome!
jamesjones's Avatar
That's exactly what I did...
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 07-30-2014, 12:01 AM   #5
East Tex
Dang! That looks nice!
Old 07-30-2014, 12:03 AM   #6
East Tex
I asked my powder coater if he does high temp coatings and he said no. So I have to find a place to ship them and have them done, or buy the Doug Thorlys.
Old 07-30-2014, 09:05 AM   #7
Low Elco
Jet hot is in OKC, Performance Plus in Joplin, MO does them too.
Low Elco is offline   Reply With Quote
Old 07-30-2014, 09:25 AM   #8
rcrahn
rcrahn's Avatar
Look great James! Where did you have them coated? And if you don't mind sharing what did it cost? Thanks
rcrahn is offline   Reply With Quote
Old 07-31-2014, 05:44 AM   #9
jamesjones
Freakin Awesome!
jamesjones's Avatar
I go them Ceramic Coated by Powder1 in El Cajon, CA. I think it was about $150 for the pair. You'd have to call them to be sure though.
Old 07-31-2014, 05:45 AM   #10
jamesjones
Freakin Awesome!
jamesjones's Avatar
There's got to be a powder guy in your area that does ceramic coating.
Old 08-01-2014, 01:24 PM   #11
68Stepbed
68Stepbed's Avatar
M&R coatings in my area does ceramic coating. They do polished, black, white and cast iron gray colors.
http://www.amr-coatings.com/
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-01-2014, 06:30 PM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
v-bands or die...
...i need to die, cuz I haven't upgraded yet. 3bolt flanges still leak if you buy the wrong gaskets (common with guys fabbing midpipes themselves)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-08-2014, 10:14 AM   #13
Xeen
Xeen's Avatar
I don't know how much you know about clearance issues regarding exhaust manifolds and headers with CPP tubular engine stands for the LSX in the C10 so I will tell you what I know about it just incase.
You don't need the Doug Thorley headers unless you are using the CPP tubular engine stands because they are what those headers were designed for in the first place.
The CPP sheet metal engine stands are a vast Improvement in clearance and are needed to allow you to run the TBSS or Camaro exhaust manifolds.
Here is a photo of the new CPP sheetmetal perches with Hooker GM clone manifolds.
I hope this information helps you out in your decision making process.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-08-2014, 10:34 AM   #14
boostedc10
boostedc10's Avatar
I had a few sets done in the black ceramic by my guy here in Michigan. I can say the coating holds up to some abuse. I did the hot side on my last turbo build and ran it hard with no flaking or other issues.
boostedc10 is offline   Reply With Quote
Old 08-08-2014, 09:46 PM   #15
East Tex
I found out about a place in Marshall Tx, that does ceramic coating. It's a couple hours from my house, but its the closest that I can find. I think that I'm going to use my manifolds and get them coated not buy the headers. I may drop them off on my way to gamble in Shreveport lol.
Old 08-08-2014, 10:06 PM   #16
83_shortwide
Can you tell me the name of the place in Marshall? Thanks!
Bo
'83 C10, LQ4, 4L80E
83_shortwide is offline   Reply With Quote
Old 08-08-2014, 10:51 PM   #17
East Tex
DK Industries
(903) 935-0502
I tried calling them today, but the recording says that they are only open till noon on Fridays. Must be nice lol
Old 08-08-2014, 11:18 PM   #18
83_shortwide
Bo
'83 C10, LQ4, 4L80E
Old 08-09-2014, 05:14 AM   #19
mcmlxix
mcmlxix's Avatar
Make sure you pay for them on the trip out... you may not have the cash to pay for them on the ride back...
Rich
Old 08-21-2014, 03:34 PM   #20
NEWFISHER
NEWFISHER's Avatar
East Tex, sent you a PM
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 08-22-2014, 09:26 AM   #21
Billett
Billett's Avatar
I run the larger DT headers and love them. They still look fantastic and I haven't had a problem yet with any leaking. That said, if you can save money and are happy with the look, GO FOR IT! Nothing wrong with manifolds.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Thread Tools
Display Modes
