Old 07-16-2014, 09:32 AM   #1
90four5spd
1972 GMC rear end help
Hello everyone. I recently purchased a 1972 GMC project truck that the rear end is very noisy , even at low speeds. There are several pull-your-part type places around here that have many 73-86 trucks I could pick up a cheap rear end from, but need help with what rear ends would work without having to weld new spring perches/shock mounts. I did use the search button, but had no luck with finding the information I'm looking for. Any help would be appreciated. Thank you!
90four5spd is offline   Reply With Quote
Old 07-16-2014, 09:47 AM   #2
boostedc10
boostedc10's Avatar
Re: 1972 GMC rear end help
I am not aware of any "direct" swap axles for our trucks outside of the body style. You will have to change the perches and shock tabs.
boostedc10 is offline   Reply With Quote
Old 07-16-2014, 12:06 PM   #3
michael bustamante
michael bustamante's Avatar
Well most gmc are leaf spring right. So couldnt a 73+rear end bolt right in?
1967custom
michael bustamante is offline   Reply With Quote
Old 07-16-2014, 12:13 PM   #4
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
They bolt in if Its leaf but those odd shock mounts with one forward and one back dont work without changing things.
Oldtruckfanatic is offline   Reply With Quote
Old 07-16-2014, 01:09 PM   #5
davepl
davepl's Avatar
If you're not a welder, I'd stick with finding one from the same year.
Have you checked the fluid level? Rear ends don't usually drift out of spec, they're usually set up right or set up wrong from get go.
There might be a "mechanic in a can" product that will quiet it down. I don't usually advocate that, but if you're next option is to replace the axle, why not?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-16-2014, 01:21 PM   #6
sKnNyPpY
sKnNyPpY's Avatar
New fluid and limited slip additive if that's what ya got. Start there and drive it till it drops.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 07-16-2014, 01:46 PM   #7
70blackfish
get the one you have fixed
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 07-16-2014, 05:58 PM   #8
90four5spd
Sorry for not giving some of the important information, but yes it is a leaf spring rear end. I am looking for the least expensive option, as I'm building up a rear coil spring frame for the truck while I am driving the GMC leaf spring frame. I just need something to get me by for now. I'm just curious if anyone has tried to install a 73-86 rear end into a 67-72 GMC leaf spring frame. Thanks for eveyones input
Old 07-23-2014, 06:00 PM   #9
Gimme Jimmy
Can I assume that you have a 1/2 ton leaf spring truck? If so, any 1/2 ton leaf spring axle from '67 to '72 is a direct fit ('71 and '72 have a 5 bolt pattern, same as the large GM cars) 4wd models use 6 bolt. The later axles ('73-on, 5 bolt) will fit, but the spring pads will require some grinding as the newer trucks have wider leaves. If you are using a newer axle you may be able to use your 6 bolt axles and drums in it (compare the parts b4 trying this). Both Chevy and GMC used both leaf and coil rear ends in any given year. The old wives tale has it that Chevy always used coils and GMC used leaves is BOGUS! either make can have either system.
Gimme Jimmy is offline   Reply With Quote
Old 07-23-2014, 10:53 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Actually in '67-'72 Chevy's came stock with coils with leafs listed as an option and GMC's came stock with leafs with coils listed as an option, so you are correct in saying that they could have either one, but only if ordered with the option.
LockDoc
Leon
Old 07-23-2014, 11:06 PM   #11
Prescott
My '67 was making a bunch of noise from the rear end, and I was sure it was going to cost me a fortune. It turned out to be a bad drive shaft support bearing (some call a carrier bearing). I rebuilt the whole drive shaft with a new bearing and three new u-joints for around 50 bucks in parts. Cured.
I'm not saying that this is the problem with your truck, but it might save you a lot to check your drive shaft first.
Prescott is offline   Reply With Quote
Old 04-11-2017, 10:16 PM   #12
davischevy
davischevy's Avatar
I had the pinion nut loosen once. It sounded like it was going to come apart.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 04-11-2017, 10:18 PM   #13
davischevy
davischevy's Avatar
Sorry, I was in search mode, ran on to this and had a senior moment. I forgot it was old news.
other Larry
Old 04-12-2017, 12:07 PM   #14
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yup... used 40+ year old rear ends are a crap shoot.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Thread Tools
Display Modes
