Old 07-17-2014, 07:56 AM   #1
Iceman_70
Iceman_70's Avatar
Gap for the headliner retainer
Can someone please measure the gap where you put the rubber retainer to hold/finish the headliner ?
Mine is between 3mm (1/8) and 11mm (7/16), so I would like to know what it should be ...
Thx,
Wim
'56 Chevy stepside shortbed
SBC350 - TH350
12-bolt rear
Iceman_70 is offline   Reply With Quote
Old 07-17-2014, 04:56 PM   #2
OrrieG
OrrieG's Avatar
Re: Gap for the headliner retainer
Sounds about right if you are talking about between the lip for the rubber and cab roof. The are not on a parallel arc. I know I am installing fabric on a backer and tried a 1/4 board and it would not slide into some of the area. 1/8" will work, I am using door edge molding to trim it out after the fabric is in.
OrrieG is offline   Reply With Quote
Old 07-18-2014, 03:15 AM   #3
Iceman_70
Iceman_70's Avatar
I'm indeed talking about that lip ... I'm still strugling a bit with translating all the terms ...
I thought it had to be parallel ... Thx for the feedback !
SBC350 - TH350
12-bolt rear
Old 07-18-2014, 12:25 PM   #4
OrrieG
OrrieG's Avatar
Back home, here are mine. Corner is about 3/16" , sides 1/4" front and back center about 3/8".
Old 07-18-2014, 02:37 PM   #5
_Ogre
_Ogre's Avatar
parallel not required the rubber hides all the imperfections.
i had similar gaps as orrieg's roof, by the time i glued 1/8'' foam and material on the roof i could not get the rubber in.
with the stock headliner you can use soapy water to lube the roof, headliner and lip
not so with ultrasuede, i destroyed a new rubber trying to get it in
i ended up using the above mentioned door edge trim
shop air compressor timer
Old 07-22-2014, 09:29 AM   #6
Iceman_70
Iceman_70's Avatar
Many thanks OrrieG and _Ogre for the feedback !
SBC350 - TH350
12-bolt rear
Thread Tools
Display Modes
