Old 08-04-2014, 05:33 PM   #1
SCOTI
SCOTI's Avatar
Dome Light Help
Would anyone happen to have a pic of the dome light opening sheetmetal on a 81-87 single cab?
My crew cab had 2 dome lights (center of roof & back cab wall). They were installed w/low (no?) concerns for craftsmanship. I'm retrofitting a pair of OE dome lights & I'm curious how the sheetmetal is shaped to get a better understanding of how to proceed.
Anyone have a pic of this or possibly can take a pic of their bare cab wall @ this area?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-06-2014, 09:38 PM   #2
SCOTI
SCOTI's Avatar
Re: Dome Light Help
Bump.....
Anybody?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-08-2014, 12:35 AM   #3
Don SC
Don SC's Avatar
Re: Dome Light Help
Here's a pic of the dome light opening in my 87 R10. The brown color around the hole isn't rust- it's adhesive from the headliner. The new headliner came with a hole cut for the light fixture. I bought the headliner from Chris Lucas, who is a frequent contributor to this site and owns his own site-www.73-87chevytrucks.com, which is a sister site to this one
Don SC is offline   Reply With Quote
Old 08-08-2014, 03:11 AM   #4
SCOTI
SCOTI's Avatar
Re: Dome Light Help
I know Chris & he's def a good guy so you can't go wrong there....
As for your pic, is the opening flat (even) w/the surrounding sheet metal surface or is the area 'raised' slightly where the screw retaining clips attach? The center dome light opening for my CC is raised so that's what drives the question.
A BIG thanks for your assistance!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-09-2014, 12:02 AM   #5
Don SC
Don SC's Avatar
Re: Dome Light Help
Hmm... flat or raised.... I can't remember. Seems like it was flat. Big help, huh?
Old 08-09-2014, 08:33 AM   #6
Chevy3+3
Re: Dome Light Help
The metal itself is flat but is contoured. You can see the light hanging in the pic has a curved mounting plate. But the metal where the clips are is flat.
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205
Chevy3+3 is offline   Reply With Quote
Old 08-10-2014, 09:55 PM   #7
Don SC
Don SC's Avatar
Re: Dome Light Help
That's a pretty good explaination 3+3 !
Old 08-10-2014, 11:41 PM   #8
SCOTI
SCOTI's Avatar
Re: Dome Light Help
Thanks.
The LMC replacements are both flat & there's no opening on my CC's roof so that should help move forward.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-11-2014, 11:46 AM   #9
Don SC
Don SC's Avatar
Re: Dome Light Help
There are LED bulbs available now. The regular bulb, a 211-2, gets pretty hot. I just ordered a new LED from that company, and then found out that AutoZone carries them.
Old 08-11-2014, 11:58 AM   #10
SCOTI
SCOTI's Avatar
Re: Dome Light Help
Yes sir, thanks for the heads up & it's why I'm putting fresh parts back in (in addition to the lights that were in there were just butt ugly). There was evidence on both center & rear lights of excess heat to the point of melting the plastic + evidence of charring.
New OE style housings & some type of LED bulb that creates less heat is the plan.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-11-2014, 12:21 PM   #11
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Dome Light Help
And any color you want.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 08-11-2014, 12:32 PM   #12
SCOTI
SCOTI's Avatar
Re: Dome Light Help
Nope.... There's only 1 choice for me
I removed 'mood' lighting from the thing when I assumed ownership (the first mods done: remove the 8 interior mood lights/lamps & cut the cowboy chrome tips off the exhaust).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-14-2014, 04:37 PM   #13
SCOTI
SCOTI's Avatar
Re: Dome Light Help
So I went looking locally for LED replacements for the 211-2 dome bulb & haven't had any luck (Pep Boys, OReillys, & AutoZone).
The only thing I could find was a bulb that consisted of a single row of 4 individual LED's. It was advertised as 10x brighter than a 'traditional' bulb but that comparison must be to a traditional bulb that's not plugged in.
My direct comparison of the traditional bulb vs the 1 & only LED replacement I found is the traditional might not be as 'bright' but it does offer more overall light vs that 1x4 arrangement. Seems more LED's will be required for improvement.
Any suggestions or specific recommendations?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-15-2014, 01:01 PM   #14
Don SC
Don SC's Avatar
Re: Dome Light Help
The 211-2 bulb was melting my housing. They do get hot! So I'm going to use the LED bulb. I"m having trouble finding a new clear plastic lens tho. When I use the original lens it won't let the LED light thru and the cab is too dark. So I've removed the lens until I can find a clear one.
I thought I saw one one on Autozone's site a few days ago, but now I can't find it...
Old 08-15-2014, 01:09 PM   #15
SCOTI
SCOTI's Avatar
Re: Dome Light Help
The ones I found listed on Autozones sight the other night were like in this pic. But when I went to the nearest store, they only had the single 1x4 bulb.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Thread Tools
Display Modes
