08-06-2014, 02:05 PM | #1 |
remove bump stops?
i lowered my 1970 c10 3/5 they were ebay springs supposed to be 2/4 but the were wrong . my front end is touching bump stops as it sits can i remove them and run w/out them to gain clearance? if so should i remove just rubber or rubber and tower. thanks for any help!
08-06-2014, 09:36 PM | #2 |
Re: remove bump stops?
You can cut the rubber down or buy the stubby bump stops.
Or remove it completely. Just remember it is also your steering stop.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy Last edited by tinydb84; 08-06-2014 at 09:38 PM. Reason: added info |
08-06-2014, 10:27 PM | #3 |
the boat guy
Id make the part that touches on the bumpstop thinner so when you hit the bumpstop its more progressive than the regular bumpstops and way beter than metal on metal.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
08-08-2014, 04:46 PM | #4 |
thanks for the feed back i think i need to remove bump stop and mount and run without it
08-08-2014, 06:06 PM | #5 |
ok i cut them off and took it for a run on some rough road...wow! thanks for the input, its so close to stock ride now,i know i have no steering stop but i can deal with that. i was bottoming out so hard before it was dropping my shifter into low. now this thing cruises!!!!
Thread Tools | |
Display Modes | |
