08-13-2014, 08:14 PM | #1 |
front end hop
when i'm going down the road i get a vibration or hop I'm not really sure what it is. it's not lifted or anything anyone have any ideas
08-13-2014, 08:26 PM | #2 | |
Re: front end hop
Balance your tires.
08-13-2014, 09:44 PM | #3 |
Re: front end hop
Need more detail.
What speeds? Does it get better or worse as you go faster? Do you feel it in the steering wheel? in the seat? Is it something you feel only, or do you hear something too? Can you do it with the truck stopped, in neutral, by revving the engine? What if you coast at that speed in neutral? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-13-2014, 09:51 PM | #4 |
Re: front end hop
i feel it in the steering wheel and in the seat a little. it does get a little better with speed.
08-14-2014, 04:03 AM | #5 |
Re: front end hop
Make sure you're front calipers are releasing also. A slight drag will over a long distance drive will get the rotor hot and out of shape.
I would look at your wheels and tires first though and check for broken belts in the tires then have them balanced. |
08-14-2014, 06:34 PM | #6 |
Re: front end hop
found my problem passenger side tie rod end is really bad
Thread Tools | |
Display Modes | |
