Old 08-20-2014, 05:23 PM   #1
makeet
1967 power steering gear box
I am having a HARD time finding a 67 power steering gear box, mine is leaking like crazy. Everybody I call says, "We have a 66 and a 68 but no 67". Any ideas? There is a place that offered to rebuild it for around $260, but was hoping to find one already rebuilt for less than that.
makeet is offline   Reply With Quote
Old 08-20-2014, 05:48 PM   #2
67c10rustbuket
67c10rustbuket's Avatar
Re: 1967 power steering gear box
1967 (or earlier) never came with an integral power steering gear. They had ram assisted power steering, completely different animal. Just buy a power steering gear box from '68 or newer, even 73+ trucks up to 1980 ? (Sometime around there they switched to metric O ring fittings).
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 08-20-2014, 09:17 PM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
68 or earlier used ram assist power steering. The 67 chassis is not dimpled for the integral gear that the 69 up used. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-20-2014, 10:17 PM   #4
colgad
colgad's Avatar
Just cut a t in the frame and hammer it in. Test fit the PS box. Weld up the t.
Takes less than an hour. Done use any 68 and up PS Box
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 08-20-2014, 10:19 PM   #5
colgad
colgad's Avatar
Forgot the last pic
Old 08-20-2014, 10:33 PM   #6
franken
Might want to post pics of the current setup so the wizards can see what you have.
You may have a conversion that you can get a rebuilt box for easily, or er, not.
franken is offline   Reply With Quote
Old 08-20-2014, 10:57 PM   #7
colgad
colgad's Avatar
Yea, we might have jumped the gun, without knowing the whole story.
Old 08-21-2014, 09:32 AM   #8
tugster67
tugster67's Avatar
what has to be done to switch mfrom manual to power steering???
tugster67 is offline   Reply With Quote
Old 08-21-2014, 03:16 PM   #9
colgad
colgad's Avatar
What year truck?
If 67 see frame mod above first
If 68-72, acquire a Power steering box
New rag joint
Power steering brackets (2 parts)
Power steering pump and pulley
Crank shaft pulley if yours is not equipped
Hoses: 1 pressure, 1 return
Be aware that you get a matched set of pump / gear / hoses
there are flare style connections and there are o-ring style connections
All work the same but you can't mix them up without having adapters $
Do some searches on the site, someone will have a kit for sale somewhere.
Old 08-21-2014, 09:22 PM   #10
EARNHARDT#3
EARNHARDT#3's Avatar
Get a box for a '78 C10. Correct fittings and only 3 1/2 turns lock to lock :-)
EARNHARDT#3 is offline   Reply With Quote
Old 08-22-2014, 12:09 AM   #11
colgad
colgad's Avatar
Good to know!!
Old 08-22-2014, 09:46 AM   #12
tugster67
tugster67's Avatar
IS THE K-10 FRAME DIFFERENT FROM THE C-10 FRAME ? Because my k-10 67 frame dont have no dimple and the power steering gear box bolts right up, maybe im going crazy???
Old 08-22-2014, 11:39 AM   #13
mikewoods
mikewoods's Avatar
Will the 67/68 pitman arm work with this 78 box?
"The Mustang’s front end is problematic, get yourself a Firebird. "- Red Forman
mikewoods is offline   Reply With Quote
Old 08-22-2014, 12:46 PM   #14
wesmigletz
wesmigletz's Avatar
I saw this at Rock Auto, under steering gear for a 1968 1/2 ton Chevy truck. When you click the link, it says they are rebuilt in the USA. I don't have any experience with them, but the price does not look bad.
LARES Part # 1075 Remanufactured; Power Gear
w/ 3 - 3-1/4 turns
box and core costs $136.79
$86.79 $50.00 $136.79
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 08-22-2014, 02:13 PM   #15
michael bustamante
michael bustamante's Avatar
Yup . Pitman arm is the same.
1967custom
michael bustamante is offline   Reply With Quote
Old 08-22-2014, 02:36 PM   #16
mikewoods
mikewoods's Avatar
Thanks!
Old 08-22-2014, 06:57 PM   #17
franken
I've been told the box is different on 4x4s but I haven't compared them.
Old 08-23-2014, 09:50 PM   #18
colgad
colgad's Avatar
I always thought all 67 frames were flat in the steering box area.
Are you sure your frame is a 67? If so do you know the build month/year of your truck?
Old 08-23-2014, 10:00 PM   #19
colgad
colgad's Avatar
1978 C10 gear on RockAuto ATSCO Part # 7512 $109 with $19 core
Old 09-10-2014, 02:56 PM   #20
mvesr
Does anyone know if the manual and power steering rag joints are the same?
Thank-Mika
mvesr is offline   Reply With Quote
Old 09-10-2014, 03:13 PM   #21
Classic Heartbeat
Frames are different but not in that area. You can shim a 4x4s gear out to bolt on because the pitman arm swings forward and back. On a 2WD the pitman arm swings right to left so centering of the steering gear becomes a problem.
They are.
Careful what you buy, you get what you pay for. Rebuilt and remanufactured steering gears are worlds apart.
No they are not. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 09-23-2014, 08:06 AM   #22
mikewoods
mikewoods's Avatar
Are the power steering boxes from the 73+ 4wd trucks different than 2wd?
Old 01-29-2015, 11:26 AM   #23
mikewoods
mikewoods's Avatar
Has anyone used this Cardone part number?
Part Number: 277512
Old 01-29-2015, 01:25 PM   #24
Lou Boffa
Lou Boffa's Avatar
How does this ratio feel? Why is it better?
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 01-29-2015, 01:32 PM   #25
EARNHARDT#3
I like it. My 2002 Tahoe is the same ratio so I'm used to it. The earlier ones I believe are 4 1/2 turns.
Thread Tools
Display Modes
