08-21-2014, 12:34 PM | #1 |
Loves all GMC trucks
Lowest production/serial number
Im not the best at searches on the board.
I have a question for some of you "experienced" members. I am looking to see if there is a thread for lowest VIN production number still on the road (or at least owned). If someone started one Id like to see it! If not... I would consider trying to get maybe the 1st hundred from each of the years documented. This site is such a repository for knowledge that in a few years it will aid in prominence if not its a good pride thing to see how many are out there. I understand many will be concerned abut their VIN being disclosed so we would maybe just verify their VIN and not post the entire thing. It would not be in this posting! I just wanted to start the conversation and say that I have a: 1972 GMC production number 032. Someone give me their thoughts? Mike
Mike If your helping someone and expecting something in return... your doing business not kindness! |
08-21-2014, 02:59 PM | #2 |
Re: Lowest production/serial number
I know there was a thread on this somewhere I have seen before.
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
08-21-2014, 07:17 PM | #3 |
I have a 69 GMC number 11 off the line
08-21-2014, 07:29 PM | #4 |
Very nice! Keep'em coming!
What are your thoughts on a database of sorts though!
08-21-2014, 10:42 PM | #5 |
Carpe manana
Mike I posted this a while back looking for the earliest 67 and last 72: http://67-72chevytrucks.com/vboard/s....php?p=6030213
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
08-21-2014, 11:29 PM | #6 | |
May not GE this year but if we document and value the history others will to someday. Thanks for sharing...
08-22-2014, 06:41 AM | #7 |
I assume you guys know that various years and nameplates have different starting points and have taken that into consideration.
I've been in several conversations with people who were confused by that (and subsequently disappointed). Also - trucks were not necessarily built in VIN order, both due to shuffling as a result of material availability/repairs and because of the aforementioned nameplate differences (ie, Chevy vs GMC). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-22-2014, 07:14 AM | #8 |
My 67 GMC was #19 off the line
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
08-22-2014, 07:15 AM | #9 | |
Kieth, Some consideration, yes. I'm just seeing the availability and interest before digging into this deeper. I would reach out to others on the board for assistance after I get a template of some kind to ensure I am gathering/considering all variables needed for this type of endeavor. Thanks for your input... Mike
08-22-2014, 09:09 AM | #10 |
08-22-2014, 09:56 AM | #11 | |
This may aid in providing additional information. Thank you for sharing!
08-22-2014, 02:20 PM | #12 |
We could start with mine:-) CE141F830855. I would be curious as to where I fall in line for production, assy plant, etc.
08-22-2014, 02:29 PM | #13 | |
Your production number is 855 for your vehicle. Ill look at it in a few and see if I can help a little.
08-22-2014, 03:47 PM | #14 | |
Here is an excellent source for decoding your VIN. Bruce and SSTIM did a ton of work to provide their combined knowledge with years of research and experience. http://67-72chevytrucks.com/vboard/s...=570059&page=3 As a reminder... Im looking to start a verifiable source document to provide future owners the earliest 100 and or even the last few trucks from each year. It could mold into each type (3/4, 1 Ton and beyond) as well if the initial thought was something others thought would be benificial. I started this thread to see if there was interest first, before I did a ton of work to get it going. I hope it helped you look into you VIN. Id check the 3rd page because it talks about the GMC Flint trucks having 3???? production numbers. Hope I helped you!
08-22-2014, 04:47 PM | #15 |
Add Mine in too CS10CTA10011
08-22-2014, 05:18 PM | #16 |
CE141F830855
C = 2wd E = v-8 1 = 1/2 ton 4 = pickup 1 = 1971 F = Flint 830855 = build sequence number This is where it get's interesting and confusing. *Info below for Chevrolet Trucks only* The Build Sequence Numbers Started with 100001 in 1967-70 and 1972. In 1971 Build Sequence Numbers started with 600001 In any year 67-72 A Build sequence number starting with 800001, meant that the vehicle was built on the 2nd assembly line at the plant. So 830855 was the 30,855 truck to be assigned a build number on the 2nd assembly line at Flint in 1971. It can even get more confusing that this if you consider rollovers or other reasons for a starting number change. EDIT: Mike, thanks for the shout out about the VIN thread that Tim and I worked on. The Starting number info on those decoders is incomplete because I didn't have enough room to add all the other possibilities. 100001 is by far the most common. And when I did those decoders I didn't even know that the 1971 Chevy trucks started with 600001. I also should have included the 800001 numbers as 2nd assembly line numbers. On those decoders we excluded a lot of info that was either uncommon or pertained to 40 and up trucks or P's, G's etc. The decoders are tailored for the trucks commonly found on this website. Last edited by bruceman1968; 08-22-2014 at 08:27 PM. |
08-22-2014, 05:28 PM | #17 |
While not very early, mines 2461 out of Flint.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
08-22-2014, 05:33 PM | #18 |
Your truck is a GMC. Gmc VINs have a different vin format and decode than chevy up to 1971. 1972 GMC's and Chevys are the same decode.
C = 2wd S = 6cyl 1 = 1/2 ton 0C = Fenderside (stepside) T = Tarrytown assy. plant A = 1969 10011 = Build Sequence Number. 1969 GMC's started with 10001 so your truck was 11th to get assigned a Sequence Number, in 1969 at Tarrytown. Last edited by bruceman1968; 08-22-2014 at 05:45 PM. |
08-22-2014, 05:39 PM | #19 |
Old Duffer
There will be some trucks that will "fall through the cracks" as far as just going by VIN number is concerned.
I have a C20 factory dually and was told by several that Chevy never built a C20 dually that the duals didn't come on until the C30 (1 ton) model. It was coded on my SPID, and still a couple of "experts" told me there was no such truck. I called the Restoration people's 800 number and after a little explanation the nice lady asked me what the VIN # was. I gave it to her and a couple of days later she called me back and said one of us mis-read the number. I read it back to her from the plate, and from the SPID. Two or three days later, she called me again and said she had good news and bad news. The bad news was she couldn't find my truck any where in the archives. The good news was she couldn't find my truck any where in the archives............then she explained. In 1968 Chevrolet didn't keep track of anything that was one percent (1%) or less of a production run. She said in '68 there were 1103 flatbed C20's ordered, but since the dually option didn't come up, my truck was one of eleven (11) or less of that configuration built. I said all of that only to say that as has been mentioned, the VIN's may not be 100% reliable in determining a particular truck's heritage.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
08-22-2014, 07:58 PM | #20 |
Bruce, i appreciate your input for sure on this. Im going to contact a few people for further info if this takes off and looks like it would be fruitful.
I have a talented friend that does a lot of database tracking. Im going to approach him on doing an automated decoder for us on the board. With so many variables I'll address unique instances to him and he can include them in the formulas or queries. As a reminder I want to document early and in some cases last few trucks. Thanks for your help!
Mike If your helping someone and expecting something in return... your doing business not kindness! Last edited by Cash3481; 08-23-2014 at 06:56 PM. |
08-22-2014, 07:59 PM | #21 |
Carpe manana
Would be great to see the earliest 67 and the latest 72!
08-22-2014, 08:43 PM | #22 |
That would be awesome!
Also brings up about 15 trucks though...unless I'm mistaken. 1/2 ton 3/4 ton 1 ton Dont forget... C40, 50, 60 and up, not to mention GMCs! That is where a database would help out a lot. People with these marque trucks will not sell and exchange hands a lot...I hope!
08-23-2014, 05:26 AM | #23 |
a good thread Mike,
FWIW: my '72 C30 is CCE332F106403 that could be later in the run for a Flint built 1 ton.
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
08-23-2014, 09:07 AM | #24 |
Lots of good info on this thread!
I work with tools. |
08-23-2014, 06:51 PM | #25 |
Thanks for the info on my VIN, its always nice to learn more. I own three of these trucks, the other two VIN's are CCE142A141945 and CE141S618527. The 72 sold new in Bowdon GA and the 71 sold new in Oneonta AL.
Thread Tools | |
Display Modes | |
