Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 08-27-2014, 10:35 AM   #1
blazer2007
welding ? is it rust or residue
I,m just welding up some 1 in. sq. tubing with a 110 wire feed and noticed it gets rusty color around the welds,is this residue or is it the start of rust.Just wondering cause the welds don,t have to be ground down as you won,t see them but I still want to paint it,I can get a wire brush in there to clean it up some what.
blazer2007 is offline   Reply With Quote
Old 08-27-2014, 02:43 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: welding ? is it rust or residue
Depends on the material you are welding and what kind of wire you are welding with. It could either be scale from the flux core wire, or the beginning of flash rusting. You can clean it up with a wire brush, actual rust will be harder to get off, scale will flake away.
Weld-thru primer is good for this sort of thing, as you aren't left with a surface that has been exposed.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-27-2014, 04:11 PM   #3
tinydb84
tinydb84's Avatar
Are you taking about the silica? How long after the weld does it show up?
David
Instagram: myfabguy
Old 08-27-2014, 07:07 PM   #4
franken
Sounds like he's using flux core wire.
franken is offline   Reply With Quote
Old 08-27-2014, 08:01 PM   #5
tinydb84
tinydb84's Avatar
Even solid wire has brown **** on it.
David
Instagram: myfabguy
Old 08-28-2014, 01:02 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
out of shielding gas, or real thick metal? splatter city
Old 08-28-2014, 01:04 AM   #7
tinydb84
tinydb84's Avatar
Neither. Wire speed way low. Was messing around trying that mig like tig thing
David
Instagram: myfabguy
Old 08-28-2014, 01:10 AM   #8
imjeff
imjeff's Avatar
Silica and splatter.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 08-28-2014, 09:06 AM   #9
blazer2007
Is solid core .023 wire and it shows up right away but looks like it is residue from the replys
Thread Tools
Display Modes
