Old 08-31-2014, 02:13 PM   #1
775stepside
Alternator replacement
My alternator went bad on my 77. So I'm going to get a new one but I want to switch over to serpentine belt system. What all do I need to switch over?
775stepside is offline   Reply With Quote
Old 08-31-2014, 02:27 PM   #2
bdiamond
Re: Alternator replacement
Its quite a bit of work/swapping..... You are looking at a new water pump, all the brackets, power steering pump, a different compressor or delete pulley, fuel line rigging and your timing mark probably won't be accessible with aluminum pulleys. Its doable, but if you're in a hurry just put an alternator on it
bdiamond is offline   Reply With Quote
Old 08-31-2014, 02:27 PM   #3
rich weyand
rich weyand's Avatar
Note that if what you really want is more amps, you can use a GM-12SI style alternator and get 100, 150, even 200 amps with no mods whatsoever. Direct replacement for the stock 10SI.
http://www.summitracing.com/search/d...rder=Ascending
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 08-31-2014, 02:28 PM   #4
bdiamond
http://67-72chevytrucks.com/vboard/s...d.php?t=468729
Old 09-01-2014, 11:50 PM   #5
775stepside
Only thing I would probly want to push with the alternator is a radio. I just like the serpentine belts better. I tried ordering belts off rockauto and they were wrong. I don't have ac either.
Old 09-02-2014, 11:33 AM   #6
gmachinz
If you are interested, I have a few ideas to help you out. If you determine that you'd like to swap out your engine harness for a serpentine specific one (if the old wiring is suspect, anyway) I build those and have several on hand. Additionally I stock a conversion bracket which I designed and CNC cut from 3/16 mild steel to adapt a readily available 140A 12/6 clocked GM 6" cased alternator as well. Or, you can still just keep it all stock serpentine and grab a set from a variety of GM vehicles including 88-92 Fbodies, 88-93 S-10, 88-95 trucks, etc just to list a few. A junkyard is your best bang for the buck on a conversion however, if you need to update/upgrade from stock, I have ready-mades harnesses to simplify at least the wiring side of it. PM me if you have questions about any of it!
gmachinz is offline   Reply With Quote
Thread Tools
Display Modes
