Cross Member swap engine mount question
Found a line a used x-member from a 78'. The 78 is set up for a big block. My current x-member is set up for a small block. Can I just take my old mounts and and use with the 78' x-member? My truck is already set up for disc brakes and power steering but the current x-member was pancaked and rides like a turd. Want to go back to the stock x-member and do drop springs/spindles. Thanks,
Jon |
Re: Cross Member swap engine mount question
I want to say they are the same. Look at the disk brake conversion threads. They have a lot of info about front end components.
We also don't know what year your pancaked corss member is. Does pancaked mean slammed? Or cut up? Alex |
By pancaked I mean sectioned. Done horribly by PO. I can only assume the x-member in there now is the original to 66'.
60-66 Nut
![]() ![]() Join Date: Mar 2007
On the '73-'87 trucks there is no difference between small block engine mounts and big block mounts.
![]() Join Date: Sep 2006
Are your old mounts 65 or later... The 64-66 perches will line up with the holes on the later cross members. And as Capt said the others bolt up the same. Alot of GM stuff bolts up the same.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Thread Tools | |
Display Modes | |
