![]() Join Date: Nov 2013
Needing guidance and advice
Ok I know there was a thread n dimpling a 67 frame for the newer power steering gearbox but I can't seem to find them. Whats the best way to get it accomplished? Thanks in advance!!!!
![]() Join Date: May 2014
Re: Needing guidance and advice
subscribed.!
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" |
Use a mighty hammer and pound it in submission where the steering box would protrude into the frame, doesn't need to go far. mmay need to apply a lil heat . Even herd of some people just running spacers too.
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll Last edited by BlackedOut67shorty; 09-06-2014 at 02:29 AM. |
Here is how I fixed my frame for Power steering. Took a section of a front frame bracket (same gauge as the frame) and widened it a bit at the top. Cut a hole in the frame and welded in.
I wondered if I couldn't run spacers. That's what I think I might try as my frame just got blasted and powder coated and I really don't like the idea of heating it or beating the heck out of it. I'm not sure that I won't have to notch the core support bracket a little also if I tighten the gearbox to the frame. I think a 1/4" spacer on all bolts will do the trick.
you could also shave a tiny amount off the back of the steering box.
I have read on here that spacers throws off your steering geometry but alot of guys have done it. btw nice job rick
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
2WD Jimmy
![]() Join Date: Mar 2005
I used a couple of washers behind an 86 power box on a 69. (The 86 up box is a little bigger) It worked just fine. I drove the wheels off that truck. There is no reason I can see why you could not just double up some washers between the box and frame like I did.
Have you tried bolting it on or are you assuming it won't fit without dimpling or spacers.
Some 67 frames need no modifications. |
Yeah I tried bolting it on and the bottom will touch but the top sticks out 3/8". So I think if I would role it up just a little it would even out at about a 1/4".
Thread Tools | |
Display Modes | |
