Old 09-14-2014, 09:19 PM   #1
mpierce9
DIY Soft top Bikini top
This may be specific to Blazers and if so I'll move it I do believe the question should be general enough for all to participate.
I'm making a soft bikini top (A top that just covers the front seats). I'm using a marine grade canvas and nylon webbing. It will attach above the windshield and wrap over the roll bar where the nylon straps will tie it down to the bed.
My question: "How would I go about attaching this top to the truck above the windshield?"
mpierce9 is offline   Reply With Quote
Old 09-14-2014, 11:26 PM   #2
truckster
truckster's Avatar
Re: DIY Soft top Bikini top
The traditional method is to drill and screw in snaps on the windshield header. There are several alternative ideas out there, though.
truckster is offline   Reply With Quote
Old 09-14-2014, 11:52 PM   #3
Blazerowner
Blazerowner's Avatar
I made an aluminum piece that attaches to the original anchor points for the top to install my soft top. I can post a picture if needed and I have about 30 bucks into it. Took a little work, but I could make it better if I had my welder using sheet metal.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 09-15-2014, 08:15 AM   #4
jjzepplin
jjzepplin's Avatar
I bought mine at 4wparts for a Jeep. It has two aluminum channels that screw to the front windshield frame. The top has a stiff piece of plastic that is stitched into the front inside the material. You slip the stiff part into the channel (channel face toward front of truck) and then it flips over toward the rear and straps to the roll bar. It's a little thinner than I would like in width but I am going to just sew on some more material on the sides. Better than trying to come up with my own.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-15-2014, 10:23 PM   #5
my71gmc
my71gmc's Avatar
I would appreciate seeing pictures Blazerowner - thanks!!!
my71gmc is offline   Reply With Quote
Old 09-17-2014, 01:19 PM   #6
Blazerowner
Here's what I came up with and works pretty good.
Kirk
Old 09-17-2014, 03:59 PM   #7
mpierce9
This does look like what I'd try to do. Thanks for sharing. Do you have additional images of this?
Old 09-17-2014, 08:05 PM   #8
Blazerowner
I might able to get some in a few days.
Kirk
Old 06-17-2017, 09:15 PM   #9
gmc1971harwich
gmc1971harwich's Avatar
Il take one of those for my 72 jimmy if ur making them 👍
gmc1971harwich is offline   Reply With Quote
Thread Tools
Display Modes
