Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 09-17-2014, 02:12 PM   #1
BC/FABRICATION
Bc/fab's 63-72 c10 bolt in air kits
63-72 C10
Our kits are available in four different levels to suit your taste and budget. If you need any help deciding what's right for you, just send a message our way and we'll be happy to help!
www.bcfab.com
shop 916-944-3916 ASK FOR JAY
cell 916-628-9188 ASK FOR JAY
email jay@bcfab.com
BCFAB IS OFFERING 10% OFF TO C10 FOURM CUSTOMERS
BC/FABRICATION is offline
Old 09-17-2014, 02:15 PM   #2
BC/FABRICATION
Re: Bc/fab's 63-72 c10 bolt in air kits
Complete FBSS Airbag Suspension Kit - 63-72 Chevrolet C10 - LEVEL 1
Part Number BK111-1 $On sale:
$999.00 YOU STILL GET 10% OFF CALL FOR SHIPPING
hese C10 Pickups (as well as the Suburbans and Blazers) have gone WAY up in value over the past several years, and you want to be sure to keep its value as you modify it! We've carefully assembled this kit using the best components in the industry to make sure your truck retains its value while giving you a slammed stance and a comfortable ride. Designed for easy installation, our mounting brackets require ZERO cutting or welding for installation, and your truck can easily be reverted to stock with little indication it was ever modified, should you desire a fully-restored look later on.
Here's what's included:
-Air Lift Dominator airbags- 8" of travel, 1/2" ports, 600 psi burst rate (four included)
-Stainless Steel Control Panel w/ 2 Dual Needle Gauges & 4 Manual Control Valves- Compact design, easy installation, four corner independent control
-Viair 480C Chrome Air Compressor - includes 200 psi chrome air compressor, relay, pressure switch, and more
-5 gallon ALUMINUM air tank- perfect size for your ride, aluminum won't corrode or rust. Mounting feet on bottom for easy installation in your trunk.
-100' roll of 1/4" DOT approved air line
-Brass DOT approved PUSH-CONNECT air fittings- no leaks or failures with these quality parts! Watch out for inferior kits looking to save a buck by sending you plastic non-DOT fittings!!
-Front airbag bracket set- designed to fit your factory spring pockets and lower control arms.
-Rear airbag bracket set- designed to fit your factory frame rails and axle.
This system is designed for simplicity over speed- the manual valves will lift or lower your ride in around 7-8 seconds. If you're looking for something faster, we have electric systems available as well, but this kit is designed for people that want to set their height and cruise! This is our "LEVEL 1" kit, but it doesn't sacrifice quality or reliability to save you money!
The pictured truck has this system installed without a frame notch or drop spindles- when the system is dropped your rear axle will set on the frame, and the front will sit at nearly the same height. Adding a frame notch, lowering blocks, and drop spindles will drop you another 2+ inches without any major fabrication. Going lower will require some major work, though!
We include complete installation guides for the installation of the airbags, as well as plumbing and wiring diagrams to make things as painless as possible. Installation on these trucks requires only basic hand tools and a drill, and can be done in a weekend. Feel free to ask any questions about putting this kit in and we'll be happy to assist! We love hearing from our customers and seeing their projects come together.
Old 09-17-2014, 02:18 PM   #3
BC/FABRICATION
Complete FBSS Airbag Suspension Kit - 63-72 Chevrolet C10 - LEVEL 2
Part Number BK111-2 On sale:
$1,399.00 ON SALE YOU STILL GET 10% OFF CALL FOR SHIPPING
hese C10 Pickups (as well as the Suburbans and Blazers) have gone WAY up in value over the past several years, and you want to be sure to keep its value as you modify it! We've carefully assembled this kit using the best components in the industry to make sure your truck retains its value while giving you a slammed stance and a comfortable ride. Designed for easy installation, our mounting brackets bolt in place of your stock coil springs, and your truck can easily be reverted to stock with little indication it was ever modified, should you desire a fully-restored look later on.
-8 3/8" Electric Valves- 250 psi rating, 4.5cV (FAST response!), virtually bulletproof (8 included for four corner independent control)
-Viair 380 Chrome Compressor Dual Pack- includes two 200 psi chrome air compressors, relays, pressure switch, and more
-50' roll of 3/8" DOT approved air line
-AVS 7 switch control box- this handheld controller hides easily and fits nicely in the palm of your hand.
-Rear airbag bracket set- designed to fit your factory spring pockets and axle.
-Bolt-on Frame Notch Kit- this notch, combined with a pair of lowering blocks, will give the rear of your truck an additional 2" of drop with no other modifications.
This LEVEL 2 system uses the same airbags and brackets from our LEVEL 1 kit, but gives you larger lines with electric valves for a faster response when you hit your switch to lift or drop. The dash-mounted control panel gets swapped out for a handheld controller that conceals easily and provides easy adjustment of each corner, as well as front, back, and all four wheels at once.
The pictured truck has this system installed without a frame notch or drop spindles- when the system is dropped your rear axle will set on the frame, and the front will sit at nearly the same height. Adding the included frame notch, some lowering blocks, and drop spindles up front will drop you another 2+ inches without any major fabrication. Going lower will require some major work, though!
Old 09-17-2014, 02:20 PM   #4
BC/FABRICATION
Complete FBSS Airbag Suspension Kit - 63-72 Chevrolet C10 - LEVEL 3
Part Number BK111-3
Your Price:
$1,599.00 TAKE OFF YOUR 10% CALL FOR SHIPPING
These C10 Pickups (as well as the Suburbans and Blazers) have gone WAY up in value over the past several years, and you want to be sure to keep its value as you modify it! We've carefully assembled this kit using the best components in the industry to make sure your truck retains its value while giving you a slammed stance and a comfortable ride. Designed for easy installation, our mounting brackets bolt in place of your stock coil springs, and your truck can easily be reverted to stock with little indication it was ever modified, should you desire a fully-restored look later on.
-AccuAir VU4 4-way Valve Manifold- Compact design, easy installation, four corner independent control
Our LEVEL 3 kit builds upon LEVEL 2 specs, but upgrades the individual air valves for an AccuAir VU4 manifold valve for a simpler and more compact installation with less plumbing and wiring.
Old 09-17-2014, 02:21 PM   #5
BC/FABRICATION
Complete FBSS Airbag Suspension Kit - 63-72 Chevrolet C10 - LEVEL 4
Part Number BK111-4
Your Price:
$2,499.00 TAKE OFF YOUR 10% AND CALL FOR SHIPPING
-Viair 480 Chrome Compressor Dual Pack- includes two 200 psi chrome air compressors, relays, pressure switch, and more
-AccuAir eLevel Ride Height Control System- height sensors at each wheel let you program 3 pre-set ride heights; handheld digital controller allows you to adjust your height at the touch of a button!
Our LEVEL 4 kit represents the way we'd build your ride if it was ours! In this case, Viair 480C air compressors and an AccuAir valve manifold with their eLevel automatic ride control, with everything else from the LEVEL 3 system carried over. Sure, you can still spend more money on chrome air tanks and such, but the equipment in this package is the highest quality for your ride!
Old 09-17-2014, 02:41 PM   #6
BC/FABRICATION
We also offer different air management systems as well so you can change up your package
Old 09-18-2014, 03:17 PM   #7
BC/FABRICATION
AutoPilot v2 Digital Ride Height Controller
The sleek V2 controller is protected in a rugged, rubberized coating to help protect against the occasional drops and scratches. Display readout shows individual corner air pressure and tank pressure. You can select your pressures to be displayed in PSI, or for our friends across the pond, we now have an option for BAR!! To give you the ultimate in personalization of your system we have loaded the multi-color display with 512 color combinations! Believe it or not all of this technology fits in the palm of your hand and only takes one wire to connect to your wire harness.
Not only does the V2 give you 8 different presets to tailor to your ride heights needs, but it also “learns” your vehicle to provide incredible accuracy with every push of the button. As you roll low, the V2 will constantly monitor your pressures and adjust accordingly to your presets. V2 also allows you to control your system manually, for the ultimate in independent 4 corner adjustment. With the raise on start feature, you won’t even have to touch the controller! Fully laid out? Raise to your ride height as soon as you turn on your ride and you’re ready to go.
You want diagnostics? Well V2 has diagnostics! With a touch of a button you can check compressor performance and compressor run times. The system will also alert you to a leak, a low pressure situation, communication failure or if there is something wrong with your valve.
Installation could not be easier! Mount your components, hook up 3 wires, plug in the OEM quality harness and you are ready to go. The detailed instruction manual will take you through the calibration and ride height preset process. Each V2 is 100% function and leak tested at the factory after assembly, so you can cruise the streets in confidence!
One of the best features of the Air Lift Performance Auto Pilot V2 is that it is proudly made in the United States of America!
This Kit Includes:
AutoPilot V2 Digital Controller
Air Line (Select 1/4" or 3/8")
Advanced Air Lift Manifoldhttp://youtu.be/8FJo_CGun80
Old 09-19-2014, 01:25 PM   #8
BC/FABRICATION
We have all the viair's available as well
Old 09-26-2014, 12:40 PM   #9
BC/FABRICATION
63-72 Chev C10 Bolt-in Frame Notch Kit
Part Number MCG-63167
This frame notch kit is designed to follow the profile of your frame, and provides an additional 2.5" of clearance for your axle. Made of 1/4" thick steel, it's stronger than the section of frame you're cutting out! Can be bolted into place, or welded for even more strength.
Old 09-26-2014, 12:43 PM   #10
BC/FABRICATION
8-Piece 8" Frame Notch Kit
Part Number FB330
This is an eight piece kit constructed of 10 gauge cold-rolled steel. These weld on notches are a universal fit for almost any truck and are a must to if you want to lay your frame on the ground. If you don't want to cut the bed and drag frame, simply cut the notches down to the size you want before welding them in. The notch provides the extra bracing required for mounting our rear bag brackets, and make for a stronger than stock rear frame section.
Closed Thread
airrdie airbags accuair
Thread Tools
Display Modes
