09-22-2014, 06:49 PM | #1 |
CPP Big Brake Install Help!
I'm finishing up installing my big brake kit from CPP on my 69. I bought new stainless hard lines from them and I'm running in issues with what goes where. CPP doesn't give instructions on how to run the lines and I can't figure it out. I'm also using a CPP booster, master, and proportioning valve. Anyone that has them, would you mind snapping some pictures of yours? I need the front and passenger side at the caliper and the lines at the proportioning valve. Thanks in advance
James |
09-22-2014, 06:50 PM | #2 |
Re: CPP Big Brake Install Help!
Btw truck is a 2wd, SWB if it makes a difference
09-22-2014, 08:05 PM | #3 |
The cpp lines I bought ended up in the garbage. Hope you have better luck
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
09-22-2014, 08:16 PM | #4 |
Part numbers? I can dig but don't want to start with "google CPP".
09-22-2014, 11:12 PM | #5 |
I'm using this brake kit: 6772FRBK6-BB. Using these lines: 6770FLK-SS. I was told by cpp when I called and emailed them that I had to finesse (ie bend) them to make them fit. I got them on but would still like to see others to compare.
Thread Tools | |
Display Modes | |
