Old 09-24-2014, 11:21 PM   #1
Houses
Ball Joint Wont Sit In Spindle
has anyone had this problem? I changed my stock spindles to drop spindles but when I was tightening everything up I noticed they weren't sitting in all the way. anyone know what I may have done wrong or what I should do to fix it? thinking of taking it out and trying to reseat it.
Houses is offline   Reply With Quote
Old 09-25-2014, 07:08 AM   #2
PGSigns
PGSigns's Avatar
Re: Ball Joint Wont Sit In Spindle
Pics are not real clear. What year truck and what year spindles? looks like it is a year mis match. May be as simple as a new lower ball joint.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-25-2014, 10:45 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yes, there are three different year break down for spindles,
63-70
71-72
73-87
You must match the ball joints to the same year spindle. Since you don't list what year your truck is, it's hard to know what to tell you. Some more info would be helpful, like year of truck, did it already have disc brakes or drums, etc.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-25-2014, 11:20 AM   #4
Houses
It's a 1974 c10 already had the disc brakes on it. They are 1.25 thick.
Ill take some better pictures tonight after work.
Old 09-25-2014, 11:44 AM   #5
PGSigns
PGSigns's Avatar
Those may be 71 or 72 spindles.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 10-14-2014, 11:55 PM   #6
Houses
sorry for the late update but everything was fine and correct. my problem was the boots did not have grease. once I greased it up the rubber covered what it was suppose to and the wheels straightened up. the top of the tire was leaning in on both sides.
Thread Tools
Display Modes
