Old 09-26-2014, 09:10 AM   #1
1961Apache
Torsion bar adjustment 1961 C-20
I noticed the left side of my pickup is down slightly lower than the right.
Is there an adjustment to either raise the left or lower the right?
1961Apache is offline   Reply With Quote
Old 09-26-2014, 11:04 AM   #2
LVPhotos
LVPhotos's Avatar
Re: Torsion bar adjustment 1961 C-20
Passengers!
If it is a torsion bar set up you can adjust them by tighten or loosening them. Check to see if something is not causing it to lean. Mark your bolts before you adjust, so if you don't like it you can go back.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Thread Tools
Display Modes
