Old 09-26-2014, 08:47 PM   #1
jimmy18841
my 1965 chevy c20
hello this is my first time on one of these sites. I was wondering if anyone would know what newer frame would fit under my 1965 chevy c20 long box truck. I want disc brakes and to put in a 350 as of right now it has 8 bolt diffs and a straight six with a 4 speed tranny. Any help would be awesome thanks Jimmy
jimmy18841 is offline   Reply With Quote
Old 09-26-2014, 09:17 PM   #2
hotrod66
hotrod66's Avatar
Re: my 1965 chevy c20
frame swap is allot of trouble and usually dont work very well. 71-87 front cross-member will bolt in relatively easy with the engine out u just need a adapter plate to mount the power-steering gear box.
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 09-27-2014, 12:48 AM   #3
Captainfab
60-66 Nut
Welcome to the forum
You do not want to change the frame. There are much easier ways to get what you want. Just do some searching thru the '60-'6 FAQ index and you will find links to threads that will help you with just about anything you want to do to your truck.
Old 09-27-2014, 12:13 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Welcome!
I would do what these other fellas are saying, look on those FAQ's, they will make things so much easier to understand.
You can do the upgrades as time\$ allow. Disc brakes, then motor, then ?
Good luck and welcome!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Thread Tools
Display Modes
