09-27-2014, 05:04 PM | #1 |
191 tilt column
I got this rebuilt column with my 1971, can anyone tell me if it is a 68-72 column or exactly what year? Thanks.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
09-27-2014, 05:32 PM | #2 |
Carpe manana
Re: 191 tilt column
Looks like a true truck tilt column to me and correct for 69-72 I believe
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
09-27-2014, 05:39 PM | #3 |
Re: 191 tilt column
I agree
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
09-27-2014, 05:58 PM | #4 |
Re: 191 tilt column
No, it is a van column with the correct length shaft for a truck!
09-27-2014, 06:14 PM | #5 |
Carpe manana
Re: 191 tilt column
Oh, is it the position of the neutral safety switch higher up on the column?
09-27-2014, 06:15 PM | #6 |
Re: 191 tilt column
I hate to disagree with 70 short fleet cause I know he knows his stuff and I may be wrong but it looks kinda like a motor home column to me. but then again it has been a while since I've got to look at any of my stuff much less work on it. Please forgive me if I am wrong. Jim
09-27-2014, 06:15 PM | #7 |
Re: 191 tilt column
The angle of the shifter arm is what makes me trigger that memory.
09-27-2014, 07:16 PM | #8 |
Re: 191 tilt column
Jim, I do forgive you The Motor home tilts that I've got have an extra bend in the lower arm but have the correct lenght shaft. The vans also have the shorter shift lever and the N/S switch is in the middle of the column but have the longer shaft. Someone has either put the correct lenght shaft in a van tilt or someone put the correct lower shift arm in a motor home tilt. That's my story and I'm sticking to it!
09-27-2014, 08:23 PM | #9 |
Re: 191 tilt column
I can be wrong all day as long as you do as good as a job on the next cluster as you did on the last one I got from you. Even though I put it in and a tilt at the same time I have only driven it like 9 miles since then. That is shameful I know. Time slips away from me so easy now I think I'll do it a little later and a couple of years pass. I am getting things in and out of the shop, just not my trucks.
Thread Tools | |
Display Modes | |
