09-28-2014, 12:39 PM | #1 |
Source for the upper control arm studs
Getting ready to do the 73 to 87 swap on the front of the 66 and I need a set of the upper control arm studs. Mine are looking pretty poor. I would like to put the 73 to 87 studs in it since the are a little longer. Been looking and have not found them anywhere. Any suggestions?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-28-2014, 06:43 PM | #2 |
Re: Source for the upper control arm studs
I bet the '73-'87 folks would know...
-W |
09-28-2014, 09:12 PM | #3 |
I cant find the thread, but someone here replaced them with grade 8 bolts. I am wanting to do the same, however I am not sure if they would snap or not. Different kind of load being placed on them than just straight pressure. Maybe im wrong here.
09-28-2014, 10:30 PM | #4 |
If Classic parts doesn't have. I would try Chevy Dealership.
09-29-2014, 06:33 AM | #5 |
Called chevy and no go. I can get the later model bolts that are hex head. The later trucks have easy access to get a socked on them. Grade 8 would take the load no problem its just a pain to get to the heads to hold them with the headers and other stuff in the way. Makes adding a shim a two person job. On the hunt still.
Jimmy
09-29-2014, 07:40 AM | #6 |
Lmc has them. I just replaced mine.
09-29-2014, 08:41 AM | #7 |
67-72 parts collector,…
Classic Parts of America shows C20/C30 studs.
I wonder it they could be made to work if you enlarge the holes in upper a-arm cross shaft?
09-29-2014, 08:52 AM | #8 |
I used grade 8 bolts. Had to cut the heads off and weld them on the back side.
09-29-2014, 10:50 AM | #9 |
09-29-2014, 11:35 PM | #10 |
I have this new set from classic parts, for a C10, never opened, no longer available. I am not going to need them for my truck.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
09-30-2014, 07:06 AM | #11 |
Sent you a PM. Are they hex head ot the round head with the splined shaft?
Thanks Jimmy
09-30-2014, 10:39 AM | #12 |
I'm just glad to be here!
if that is them in the picture in the bag, they look to be round head with a knurl under the head.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
09-30-2014, 01:44 PM | #13 |
They are a flat round head with knurl. 1/2" stud x 3.125" long. I don't know if they are longer like you said, "73+ are longer" than earlier models? Classic showed 1963-91 I think. LMC does list a 1/2 ton stud in their catalog but I heard (in the past) that they were wrong. Just pay what I paid for them if you want them.
09-30-2014, 02:31 PM | #14 |
I have a set on the bench and will measure them when I get home. Will let you know what I find out on the length. They do look like the right ones.
Thanks Jimmy
Thread Tools | |
Display Modes | |
