09-29-2014, 01:12 PM | #1 |
c notch question.
I'm sure this has been asked before, I saw a few other posts, bit does anyone have a definitive answer as to how much you can drop the rear without a c notch?
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
09-29-2014, 01:34 PM | #2 |
Re: c notch question.
You can do a 5" drop without having to c-notch. I will recommend a c-notch if you plan to haul things, to allow for a little extra clearance. I believe a few guys have done a 6" without a notch.
09-29-2014, 02:57 PM | #3 |
When I bought my truck the previous owner lowered it about 6 inches by heating 2 inch lowering coils. it was the worst riding thing i had ever been in. I would use lowering blocks for 2 inches or so and then get 3 inch lowing springs if you are going to stick at 5 inches... A decent pair of shocks and it will still be bearable to ride in.
1967 c10 build finally in progress! http://67-72chevytrucks.com/vboard/s...d.php?t=575626 |
09-29-2014, 03:42 PM | #4 |
///Relaxed Atmosphere
do you plan on hauling anything ?
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
09-30-2014, 01:12 AM | #5 |
Not likely, I have an 01 sierra for that. I mostly want to cruise/road race it
09-30-2014, 01:19 AM | #6 |
Moderator
I needed a notch with 5" drop springs, truck bottomed out routinely. Each truck will vary, there is no definitive answer. Install the drop springs and if you find a c notch is in order, then go ahead and install one as well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-30-2014, 06:35 AM | #7 |
I lowered my longbed with 2.5" spindles in the front and 4" springs in the rear... ECE said 4" springs on a longbed would give me about 5" and I would say they were right. I also added shock relocaters and an adjustable track bar and I did a rear sway bar as well.
While you have it all apart I suggest new bushings in the trailing arms as well. All of this in my truck made for a very nice ride and much better handling, loaded or empty. I didn't do a notch and I have about 2.5" of travel before I get to the stock bump stops which I could trim and gain another inch or so. |
09-30-2014, 08:44 AM | #8 |
Since you have the bed off (according to your build thread), I would definitely do it. Not too big of a task when you have a top view of the frame. I have a lwb rolling chassis with ECE 4/6 drop. I can't see what the actual ride height is yet without the weight of the bed on it, but I only plan on building this truck once. Better safe than sorry!
John '71 Cheyenne 10- In the works http://67-72chevytrucks.com/vboard/s...d.php?t=638156 |
09-30-2014, 03:16 PM | #9 |
like leddzepp said each truck will vary. i got mine down to 7" without a notch has not bottomed out at all but keep in mind i do not haul anything either. just play with it and see where you end up.
09-30-2014, 09:59 PM | #10 |
4.5"/6.25" here. No c-notch. Rear bump stops cut 1/2 way. Rear has never bottomed out.
10-01-2014, 01:27 AM | #11 |
Question for you, what wheel tire combo are you running, it looks like what I have , (15×10s with 275/60/15s) and do 5hey rub?
10-01-2014, 08:28 AM | #12 |
Same here with 5/7 drop no c-notch. I removed the bump stop and have about 3.5-4" of frame clearance. I think a fleetside bed is heavier than a stepper so that may factor in to it also. Play truck only for me so no heavy loads.
Follow me on Instagram: @midtennc10 Youtube channel: Midtennc10 |
10-01-2014, 04:41 PM | #13 |
4/6 drop and I C-notched The rear is sitting down by 4 inch shorter springs and 2 inch blocks.
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
10-03-2014, 10:36 PM | #14 |
I have 275/60/15 all around. Unfortunately, the front tire to touch the inner fender now and then over a bump. I'd go 255's in the front next time.
10-04-2014, 12:33 AM | #15 |
What spindles are you using, it looms like your front tires are way out there? In the pic it looks like the rears tuck up nicely, but the fronts are almost out of the fender.
Thread Tools | |
Display Modes | |
