Old 09-29-2014, 09:56 PM   #1
map66
map66's Avatar
Question Lights Out
First, Greetings to all. I have a new problem with the Lights going out when I put them on bright. The lights work on dim but when I hit the switch they go out completely. I am thinking it is the switch but need advice if anyone has had this problem. All other lights are functioning.
map66 is offline   Reply With Quote
Old 09-29-2014, 11:25 PM   #2
63burban
Chevy addict
Re: Lights Out
Dimmer switch connection or switch itself.
63burban is offline   Reply With Quote
Old 09-30-2014, 07:08 AM   #3
PGSigns
PGSigns's Avatar
Re: Lights Out
Yup dimmer switch or the plug. Dimer is easy to test with a volt meter.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-30-2014, 11:06 AM   #4
TJ's Chevy
TJ's Chevy's Avatar
Re: Lights Out
Adding myself to this thread cause the same thing is happening with mine. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-30-2014, 11:38 AM   #5
LuckyLightning
LuckyLightning's Avatar
Re: Lights Out
Had this exact same thing happen to me. I replaced the dimmer switch but I still had the problem. So I replaced the headlight switch - still the same problem.
I tested for voltage and found I had power going to the dimmer switch. So I stepped on the dimmer switch a dozen times or so and noticed the clicking was loose and grinding while I got intermittent lights.
I returned the dimmer switch for another and noticed immediately the crisp and clean clicking of the new switch. Headlights now work 100%.
It's a cheap part and super easy to replace (assuming you have the correct "screwdriver", but a large flathead should work).
Michael
- 1962 C20 LB stepside (project thread) - sold
- 1963 Chevy C10 LB stepside (donor)
- 1963 Chevy C10 LB Custom flatbed (project thread) - sold
- 1979 K20 LB fleetside (project thread)
Favorite exchange on the board so far:
ol_Curt: "Jason, do you have power steering?"
jason65: "No, but I lift weights."
LuckyLightning is offline   Reply With Quote
Old 09-30-2014, 07:01 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Lights Out
First off welcome to the forum! Also be sure to check the bulbs and make sure the high beam filaments are not burned out.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-30-2014, 09:47 PM   #7
map66
map66's Avatar
Re: Lights Out
Thanks for the welcome guys and the diagnosis. Looks like I will be getting a new switch.
Thread Tools
Display Modes
