Old 09-30-2014, 03:18 PM   #1
steelhorse
steelhorse's Avatar
Trailing Arm bushings
I am ready to do some work on my chassis and want to replace the trailing arm bushings. What are you guys using and where are you getting them? I saw a kit that had reinforcing plates and bushings but they were polyurethane and didn't look to have the outer metal shell that you press into the trailing arm. How does that work?
steelhorse is offline   Reply With Quote
Old 09-30-2014, 03:24 PM   #2
leftybass209
leftybass209's Avatar
Re: Trailing Arm bushings
You reuse your original shells with the polyurethane bushings. That's what I have but not installed yet.
leftybass209 is offline   Reply With Quote
Old 09-30-2014, 05:20 PM   #3
Fldawg
Fldawg's Avatar
bought some of the rubber ones from lmc,
Fldawg is offline   Reply With Quote
Old 09-30-2014, 05:30 PM   #4
boraxman
Keepin an eye out
boraxman's Avatar
Heres a question...How do you know when they need to be replaced?
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 09-30-2014, 10:21 PM   #5
steelhorse
steelhorse's Avatar
I am doing a frame off so all my bushings are being replaced.
Old 10-01-2014, 08:29 AM   #6
engineer_gregh
engineer_gregh's Avatar
I replaced mine this summer with ones from LMC. Mine looked to be original and were dry rotted and cracked. At the same time I did new coils, shocks, CPP front stabilizer bar, new u-joints and carrier bearing, and a CPP rear track bar. Drives great but with all of that at once I couldn't tell you how much of a difference the trailing arm bushings actually made.
engineer_gregh is offline   Reply With Quote
Old 10-01-2014, 08:52 AM   #7
Number98
Prestige Worldwide
Number98's Avatar
I just did this with the Poly bushings, getting the old ones out can be tough since you have to leave the outer shell. I drilled several holes through the rubber, then pushed them right out. I put the Poly bushings in the freezer for a bit, then put the lube that comes with them on and they slide right in.
Number98 is offline   Reply With Quote
Old 10-01-2014, 03:25 PM   #8
kamikazekyle05
kamikazekyle05's Avatar
I got mine from travis at azproperformance http://www.azproperformance.com/Prot...lls-7-301.html
kamikazekyle05 is offline   Reply With Quote
Old 10-01-2014, 08:19 PM   #9
mechanicalman
I got my polyurethane from Performance Suspension in Phoenix. When I posted this, their website was under construction.
3001 N 35th Ave, Phoenix, AZ 85017
http://www.performancesuspension.co...
(602) 272-4085
It seems I had the most trouble getting the old rubber ones out, don't remember exactly how I did it but I used a wire brush to finish cleaning the inside of the old existing tubes before installing the new ones into there, they went right with the supplied lubricant. I did them with the truck fully assembled with the axle tubes on jack-stands, I loosened the U-bolts on one side at a time and dropped the trailing arm just enough for clearance one at a time and had no problems at all. I had my come-along and bottle jack at the wait, but not needed.
I HAVE HEARD since then that once you loosen those U-bolts that you need to replace them. I have not, but since I heard that it's on my to-do list. I only drive it to the dump, I know, no excuse but I'm not as young as I used to be and not as energetic.
The old bushings, after some 250,000 miles, were still good. The new bushings are nice but if I told you I could tell the difference I'd be lying.
mechanicalman is offline   Reply With Quote
Thread Tools
Display Modes
