08-13-2003, 05:54 PM | #1 |
Door Hinge Pins
I'm replacing the drivers door due to the
rust at the bottom. Also noticed that the hinges allow the door to sag about 1/2" at the outer edge of the door. So...I want to replace the hinge pins/bushings. Has anybody done this? Can to get replacements at the local parts store in the Help section? I know I can get 'em at LMC and others but I was wanting to get this done right away. Jim Mt Juliet |
08-13-2003, 07:16 PM | #2 |
I have them they come w/ the bushings and pins and are 6.00 dollars a pair plus shipping
08-13-2003, 07:17 PM | #3 |
I have done alot of them and they work fine (sometimes they require a little heat to come out)
08-13-2003, 07:35 PM | #4 |
I did the hinges on my 71 4x4 and they really aren't to much hassle to deal with. Just grind off the swaged tips and punch them out with a drift pin. Helps if you have a bench vise. I used some lithium grease when I pressed them back in and then "staked" them with a punch. Sure made a difference. Pretty straight forward re-build.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Thread Tools | |
Display Modes | |
