10-15-2014, 11:12 AM | #1 |
Ece 5.5 dropped leaf springs
Has anyone used ece 4 inch drop leaf Springs with the 1.5 shackles or at least have pictures of it
10-28-2014, 02:41 AM | #2 |
Re: Ece 5.5 dropped leaf springs
I was hoping someone tried them . I have already ordered (out of stock) 4" drop leafs , and waiting for them (ECE) to call so I can go pick them up . I will post some pics when I get them installed
01-28-2015, 05:55 AM | #3 |
Ttt
01-28-2015, 10:22 AM | #4 |
edit: I did funny math based on your post title. You wanted 5.5" drop not seven, but...
5.5" springs plus 1.5" shackle equals 7". I flipped my rear axle using a DJM kit and got 7" for only $130. I used front shocks and moved them to the more upright position using the hardware supplied and the second hole in the factory upper shock mount. I removed the rubber bumpstops and cut the "pads" on top of the axle housing off. I used DJM low profile urethane bumpstops on the frame that came with the flip kit. Front is 2 1/2" disc conversion drop spindle from ECE and their 2" small block spring.
01-28-2015, 02:16 PM | #5 |
Looks great Mike C
01-28-2015, 02:29 PM | #6 |
Here is my 69 GMC after installing the 2.5 drop spindles and 4 in. drop leafs from ECE . I am considering adding the 1.5 shackles .I also went with their disc brake kit and sway bar ,It rides great and handles like a dream now.
01-28-2015, 02:32 PM | #7 |
So the only thing u have on the rear are ece 4 inch drop leaf Springs?
01-28-2015, 02:32 PM | #8 |
Have done to the rear I mean
01-28-2015, 02:47 PM | #9 |
Yes that's all I have done to the rear 4 in. drop leafs from ECE with their shocks
01-28-2015, 02:50 PM | #10 |
That looks great so I know now I would be happy with the 1.5 shackles added to that. Your front is 2.5 drop?
01-28-2015, 02:55 PM | #11 |
Yes 2.5 drop spindles in front from ECE . I know my front springs have to be worn out so I am up in the air on lower or stock springs ,I'm thinking lower
01-28-2015, 02:56 PM | #12 |
Do you have a build on your truck?
01-28-2015, 02:57 PM | #13 |
no I don't I've been thinking about it , I've been too busy working on it though .lol
01-28-2015, 03:00 PM | #14 |
I understand that how u like the ece parts you use? I've never heard anyone say anything negative about them
01-28-2015, 03:04 PM | #15 | |
Heres a pic of my truck the day I bought it 3 1/2 months ago |
01-28-2015, 03:07 PM | #16 |
Damn what a big difference
01-28-2015, 03:17 PM | #17 |
Countless hours after work . 180 + holes ( from the trim and other things not rust ) welded up on the body. Some screaming , not too much kicking , 1 tooth and a few dollars .Time well spent , It's all good and fun
01-28-2015, 05:30 PM | #18 | |
"Life is too short to drive a boring vehicle". Later, Wayne |
01-28-2015, 08:29 PM | #19 |
Thanks. I've owned the truck 15 years and have only really driven it in the last month! Having a great time with it.
01-28-2015, 08:30 PM | #20 |
I didn't do a build thread. I have about $2500 in the disc conversion, 5 lug rear, flip, springs, wheels and tires.
01-29-2015, 05:38 AM | #21 |
In my post from a few years ago I have some pictures: http://67-72chevytrucks.com/vboard/s...d.php?t=361890
01-29-2015, 10:14 AM | #22 |
So I take it you use ece 4 inch drop leaf Springs and 1.5 drop shackles
Thread Tools | |
Display Modes | |
