10-15-2014, 09:08 PM | #1 |
rack and pinion
Anyone running one with a pancake cross member?
12-23-2014, 12:17 AM | #2 |
Re: rack and pinion
Anyone im curious as well
current project: 1964 chevy II Wagon 1956 3100 1972 c10 burb bagged 1962 GMC burb 1963 c10 burb 1966 c10 burb 1995 chevy lowerado 5/7 static drop daily driver 1963 c10 step side 1965 super sport impala 1967 c30 |
12-23-2014, 11:47 AM | #3 |
Re: rack and pinion
I am getting ready to install one in my 62 on a Porterbuilt drop member. Flaming River rack quick ratio 15:1 told the standard one is what everyone else runs. I have an extra set of rack to spindle links. I would think if you fab mount it would work. The connection would be on bottom where mine will mount on top.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
12-23-2014, 11:53 AM | #4 |
Re: rack and pinion
I know a few people have done it I did a few years ago it was a lot of work but worked out well.heres a link to the build http://67-72chevytrucks.com/vboard/s...=478965&page=2
12-23-2014, 05:38 PM | #5 |
Re: rack and pinion
I did it- you just need to push it up the same amount you cut out of the crossmember- which means c-notching the frame.
The MII rack is exactly the same knuckle to knuckle as the stock center link- so if you put it in the same position as stock (adjusted for your crossmember section) then you aren't changing the steering geometry at all.
needed - 8" x 10" patch panel for the bottom ribbed part of a 60-63 door inner panel (previous owner cut one speaker hole ???!!!) |
12-23-2014, 07:29 PM | #6 |
Re: rack and pinion
Installed one on mine in the thread
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
12-24-2014, 12:06 AM | #7 |
Re: rack and pinion
I didn't section my crossmember but I did notch the frame 1.5" to raise it. I'm using a No Limit Engineering rack kit with no clearance issues.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Thread Tools | |
Display Modes | |
