Old 10-15-2014, 10:16 PM   #1
gmebey
Need bearing advice
My project just keeps going.....starting with a front end rebuild has now sprouted into wheel bearings.
I have a C20 1969 with a 5.7L.
My preference is Timken bearings but have been striking out on finding stock for the inner bearing and race.
What are your opinions on other brands like National, SKF and AST?
Any suggestions on sources?
gmebey is offline   Reply With Quote
Old 10-15-2014, 10:21 PM   #2
Xeen
Xeen's Avatar
Re: Need bearing advice
I would just take the old bearings with you down to O'reilly's and they can put their caliper on it and find out the I.D and O.D and go get some made in the usa bearings off the shelf, or if they don't have them in stock they can order them and usually get them in the same day as long as you order first thing in the morning.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-15-2014, 10:59 PM   #3
88Ironduke
The National Bearings are fine for most people. I too prefer Timken over National and the others but at the end of the day I will use National. Its cost effective and conical bearings rarely just randomly give it up without some kind tell tale grindey/crunchy sounds before they die(IMO). The National parts are off the shelf stuff, A-3s for the outer and 2777s for the inners. Should be able to get them any where.
88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 10-16-2014, 10:43 AM   #4
bollybib
bollybib's Avatar
Inner race Timken 382 on eBay
http://www.ebay.com/itm/Timken-382-W...0299d4&vxp=mtr
Inner bearing Timken 388A on eBay
http://www.ebay.com/itm/Wheel-Bearin...827a57&vxp=mtr
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 10-16-2014, 01:20 PM   #5
Fitz
My 69 overhaul manual lists that bearing part number as 909545. The Timken equivalent is B45.
Check the dimensions of your bearing with a vernier caliper and compare to those below just to be sure. Part numbers have a habit of changing after 47 years or so.
Timken B45 Dimensions are:
Inside Diameter : 23.03 mm,0.9065 in
Outside Diameter : 57.16 mm,2.2503 in
Radius : 0 mm,0 in
Width : 20.07 mm,0.79 in
Model: 909545+909725+909625
Classes: BALL BEARING
Details: SINGLE ROW,
Other Details: FRONT WHEEL COMPLETE
Fitz is offline   Reply With Quote
Old 10-16-2014, 07:21 PM   #6
davepl
davepl's Avatar
Just FYI, never spin up a roller bearing in your hand with compressed air. Local guy lost some fingers not that long ago.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-16-2014, 07:25 PM   #7
Fitz
I had a neighbor who had a cousin whose friend's brother.....
Has all the makings of an urban legend!
Old 10-16-2014, 08:01 PM   #8
Xeen
Xeen's Avatar
Old 10-16-2014, 11:16 PM   #9
gmebey
How funny you mention the warning about spinning a dry bearing with compressed air. I just read an article from Timken about the dangers of a bearing coming apart under that same scenario.
Old 10-16-2014, 11:22 PM   #10
imjeff
imjeff's Avatar
How on earth (and where) did that happen?
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 10-18-2014, 03:25 PM   #11
bigmac73
bigmac73's Avatar
i always thought that the NAPA premium brand bearings where re-boxed timkens????
and Auto zone carries timkens I think you need the set 3 and set 4
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Thread Tools
Display Modes
