Old 08-14-2003, 07:05 PM   #1
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Doing Bags, have a few ?'s
This winter I am going to do bags. I have a 5.5" drop right now up front. If I just put in bags I will only sit around 1" lower if the bump stop is completely removed right? (3" spring, 2.5" spindles). Does anybody have any pics with bags, spindles and 2" a-arms I could look at. I would like to lay the air dam on the ground and that is around 3" from the ground. I will also be getting rid of my 3" notch in favor of a larger one. Right now I have leaf rear, but will be swapping the coil setup out of a parts truck to make things easier and cheaper. Also doing F/B/S/S how much am I looking for a descent kit? I don't need anything insanely quick, just enough to play every once in a while. And what are some common problems I should look at and what tricks work to get rid of them. I am trying to go the cheaper route, $1000ish is all I have to spend on it. Insane68 sells this stuff right? If you read this send me a price so I can start figuring stuff.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 08-14-2003, 07:47 PM   #2
BaggedC10
Under construction!
BaggedC10's Avatar
www.RideTech.com and stay away from shAIM products.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 08-14-2003, 10:24 PM   #3
Truckhead
18436572
Truckhead's Avatar
I'm lookin to bag my ride this winter also, Isn't there a bolt in 4 or 3 link rear airide set-up for our trucks? What'dya think, 18's layin frame.
Truckhead is offline   Reply With Quote
Old 08-14-2003, 10:44 PM   #4
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
I wouldn't buy a kit, I would go ahead and buy all your components seperatly, that way you can get the parts you want and possibly for a lot cheaper. I did a F/B system and installed it myself for a little over $500. However this is without drop spindles and a notch which will come later It sits plenty low for now, as I dont plan on dragging the frame/body al over town....yet
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 08-15-2003, 11:59 AM   #5
fastbagged68
fastbagged68's Avatar
I can get you guys what your looking for! PM me! Check out www.dragginbycustoms.com
fastbagged68 is offline   Reply With Quote
Old 08-15-2003, 01:35 PM   #6
Slammed67
Progress = 0%
Slammed67's Avatar
LOL.... that's what I thougt too!
...... but once you get the bags installed, you'll want to play with them more often than that!! Trust me! You might not need (or want) something super fast, but you'll want the most air supply you can get (or afford). I have two 3-gallon tanks that are about 120-130psi when full. That doesn't allow much "play" time before the compressors kick on. The rear doesn't require much air to lift, but the front eats up quite a bit.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 08-15-2003, 01:56 PM   #7
lost wages
lost wages's Avatar
i had a little fun with your truck, hope you dont mind. What size tires and wheels are you running?
lost wages is offline   Reply With Quote
Old 08-15-2003, 01:58 PM   #8
Slammed67
Progress = 0%
Slammed67's Avatar
Hey, can you center those front wheels?? (front to back)
Old 08-15-2003, 02:14 PM   #9
fastbagged68
Slammed67 you should run a higher pressure switch- I run in all the trucks that I do a min. of 145psi but with my pressure switches they come on after a 20psi drop so you should never get your system to 115psi unless you are just playing and playing and playing with the switches.
Slammed67 also said it on the dot. You wont be satified with buying the slow stuff or small tanks. All the cars I have done I told my customers they should run more then 6 gallons of air they all said no. Well within a month they all want more air tanks, and bigger valves. I recommend 9-12 gallons of air if you have the room and plan on playing, but if you dont plan on playing then 6-7 gallons is enough.
By the sound of it you will want probably 2 -5 gallons tanks, 8 valves, and 2 compressors. I can make you up a pipmp ass systme for fairly cheap- PM me for more info!
Old 08-15-2003, 02:45 PM   #10
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Just PM me or e-mail and I'll quote ya everything.
I will back my product's 100%, and I don't have to TRASH another product to make mine look better.
I've been a board member for a long time. If you wanna buy from me that's cool. Look forward to doin business with you.
Later NSANE68!!!
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 08-15-2003, 02:56 PM   #11
lost wages
lost wages's Avatar
heres a quick one
Old 08-15-2003, 02:58 PM   #12
Slammed67
Progress = 0%
Slammed67's Avatar
Ahhhhhh...... much better! That's the problem I fixed on my front suspension.
Old 08-15-2003, 08:29 PM   #13
BaggedC10
Under construction!
BaggedC10's Avatar
Just for the record, I don't sell ART products.
Old 08-15-2003, 09:09 PM   #14
Izzy
Trucker.
Izzy's Avatar
And?
It doesn't hurt to use quality products.
Izzy is offline   Reply With Quote
Old 08-16-2003, 01:32 PM   #15
72chevyLWB
Got 20's????
72chevyLWB's Avatar
What do I have to do to get it to lay that low? And a little has to be taken off the back of the box. The wheels are Eagle 221's. 8's in front 9.5's in the rear. I know a guy here in town with a 9 gallon tank, but its only 2 port and he also has a compressor. I can't remember off the top of my head which one it is. Its a BloJax 3/4 hp 100% duty though for $150. Is that a deal?
Old 08-16-2003, 02:10 PM   #16
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Old 08-17-2003, 12:47 AM   #17
lost wages
lost wages's Avatar
you will need a pretty good size step notch to lay it down, front is easy bags and spindles.
Old 08-17-2003, 12:50 AM   #18
lost wages
lost wages's Avatar
oops, your right, i forgot to take some out of the back of the bed on the pic i did of your truck. what size tires are you running? if you want any help IM me, ill do what i can.
Old 08-17-2003, 01:57 AM   #19
loweredd
www.loweredd.com
loweredd's Avatar
I just noticed those were 221's. I ALMOST got those for mine. Mine is in the process of getting bagged right now. Its slow goin with a broken arm though.
loweredd is offline   Reply With Quote
Old 08-17-2003, 05:49 PM   #20
72chevyLWB
Got 20's????
72chevyLWB's Avatar
The tires are 245/35's in front and 275/30's in the rear. Bridgestone Pole Position S-03's. I got everything for $1 over cost thats why I got them. Wheels and tires together for $1600. But I just smacked a big pot hole the other day so I have to get 2 more wheels.
Old 08-17-2003, 08:48 PM   #21
loweredd
www.loweredd.com
loweredd's Avatar
that's exactly why I am not gonna run a rubberband tire. I've got 305/50/20 for the back. I think that I might do a 275/55/20 up front. That's about the same size sidewall.
Old 08-17-2003, 09:08 PM   #22
Izzy
Trucker.
Izzy's Avatar
That's a very nice frame.
Old 08-19-2003, 09:50 AM   #23
kxmotox247
kxmotox247's Avatar
TTT
Just following along here because this is something I might be trying in the future.
I lie the idea of adjustable ride height but I don't know about cutting my frame up/putting in a 9" rear or any of the other issues associated with going that low. Can you still bag a truck and not cut the floor or alter the wheel tubs? Is a c'notch enough by itself? I know very little about air ride so forgive me if my questions seem amateur.
The front air is an easy install, right?
The rear is more difficult...requires welding. What is recommended for the rear?
Thanks!
kxmotox247 is offline   Reply With Quote
Old 08-19-2003, 10:12 AM   #24
Izzy
Trucker.
Izzy's Avatar
Originally posted by kxmotox247
TTT
Thanks!
You can absolutely do bags w/ just a bolt on notch and a stock axle. If you run the bolt on notch it wont be as low but obviously you’re only wanting to have the adjustability.
Front is real easy, pull the coil and slap the bags and brackets in place.
The rear will normally require you to weld on a 4link to the frame and axle and some sort of bag mounts on the axle and the frame.
Old 08-19-2003, 10:17 AM   #25
loweredd
www.loweredd.com
loweredd's Avatar
You dont HAVE to notch at all.....you will be able to go lower if you do though. The front is easy to do also. Cups and bags will work for you in the front.
Stock floor body drop is just as easy as doing air suspension on these trucks if you are interested in being THAT low.
Thread Tools
Display Modes
