Old 10-20-2014, 10:47 AM   #1
Brave71
Rear brake adjustment hole??
My 71 does not have adjustment hole in mounting plate... The brake drums that came with the truck have no adjustment holes... Can I get new drums with holes?
Brave71 is offline   Reply With Quote
Old 10-20-2014, 03:13 PM   #2
Sammy
Re: Rear brake adjustment hole??
Some do some don't. Last ones I got were manufactured in Canada and had knock-outs with plugs. And had to later true the drum on one was outta round kept getting red hot. Really made my day to true a new drum. Machine shop guy said it isn't uncommon for new ones needing to be trued up.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 10-20-2014, 04:32 PM   #3
bigpaul
bigpaul's Avatar
I cut a slot in the backing plate the size of the rubber plug. Problem solved. I think I used my dremal tool.
bigpaul is offline   Reply With Quote
Old 10-20-2014, 05:02 PM   #4
72bowtiestepper
My 72 C-10 had knock-plugs in the backing plate.
72bowtiestepper is offline   Reply With Quote
Old 10-20-2014, 05:30 PM   #5
Brave71
Thanks... There was a kinda knock out in the drum, I drilled it out ,
Old 10-21-2014, 02:34 AM   #6
70 shop truck
70 shop truck's Avatar
Just to add to this one... I ran into this two weeks ago with drums from Autozone. Every drum all the local parts stores had didn't have the hole for brake adjustments ,not even the knock outs. I knocked out the unused plug on one of my old drums and used it for a template and then used my dremel to cut holes in my new drums. Wasted a bunch of time running around to different parts stores attempting to find ones with holes already cut. At my last stop there was a customer that owns a local car customizing shop who overheard the conversation we were having and let me know that on many of the new drums coming out the holes are not there and you needed to cut them. On my 70 he recommended cutting the drum as the backing plate was lighter metal and would be prone to bending when I needed to adjust.
1970 Long bed- Stress release
"There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion." Unknown
70 shop truck is offline   Reply With Quote
Thread Tools
Display Modes
