10-20-2014, 03:23 PM | #1 |
Thinking about switching to elec radiator fan.
I read a forum on here that early 90's Ford Taurus fans are a good one to use on our trucks. Any comments?
67 C10 step side 355ci 05 Z71 reg cab short fleet side |
10-20-2014, 03:35 PM | #2 |
Re: Thinking about switching to elec radiator fan.
Jeep are popular, Lincoln several threads on conversions. Wiring n relays will be needed also.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
10-20-2014, 04:11 PM | #3 |
Why the switch, if you don't mind me asking?
I use to have an electric one, but switched back to mechanical when I started having electrical issues, I hate dealing with relays. |
10-20-2014, 04:20 PM | #4 |
I've heard it gives a lot more horsepower and better cooling. And my fan won't fit in my shroud.
10-20-2014, 04:29 PM | #5 |
We have hot summers here and I am worried about overheating. But I don't won't anymore electrical problems either. I already have a battery draw that I can't figure out. I appreicate everyone's input!
10-20-2014, 04:42 PM | #6 |
If you start adding stuff power windows, huge draw amp, clock, air compressors, headlights, n air you actually tax your electrical system pretty hard for our stock alternators. I personally think it is a worthy upgrade for the fans. But maybe not to everyone's taste.
10-20-2014, 04:57 PM | #7 |
There are some great topics on this.
http://67-72chevytrucks.com/vboard/s...d.php?t=585573 I bought an aftermarket shroud and an oem fan, runs smooth and cool with no problems. You can't go wrong with either one. But I would definitely take care of that electrical issue first. |
10-20-2014, 04:59 PM | #8 | |
Why not get the right shroud for your truck and be done with it? Hell of a lot better than driving around with Taurus fans on a switch. Plus it doesn't sound like your electrical system is currently up to the task of running a 30 amp fan or whatever it is.
10-20-2014, 05:44 PM | #9 |
I was overheating on long grades in 110 + temperatures. Because I had radiator leaks I installed a new 4-row radiator from Autozone (less than $100), and since then my temperature gauge sits at the thermostat point in any temperature Phoenix can throw at me, using the stock clutch fan and shroud.
If it ain't broke, don't fix it, in my opinion.
1971 C10 Longbed, 350/TH350 |
10-20-2014, 05:53 PM | #10 | |
Still running the stock 6 cyl. rad in mine, with a clutch fan and electric backup. Does ok on cool days but think I will need more rad when it gets hot outside again.
1967 GMC SWB 383 Stroker w/Saginaw 4sp 1979 Chev C30 Scottsdale Flatbed 350 4sp 2000 Chev 3500 Flatbed 454 Automatic 1978 GMC 6500 Flatbed Dump 366 5sp + 2sp 1965 Chev K10 LWB 230 4sp 1985 Chev K30 Flatbed 350 4sp |
10-20-2014, 09:12 PM | #11 |
sorry
67 C10 step side 355ci 05 Z71 reg cab short fleet side Last edited by bevos68bowtie; 10-20-2014 at 09:17 PM. Reason: Wrong person |
10-20-2014, 10:56 PM | #12 |
Sorry, no I don't, and when I looked at the Autozone website the only one they show now is $186. The one I got was copper/brass, and looks just like the OEM part.
It was 3 or 4 years ago, and my point was not to promote any particular radiator, but to say that the stock cooling system works just fine in my truck in a severe climate.
Thread Tools | |
Display Modes | |
