Old 10-25-2014, 10:57 PM   #1
thumpernickle
Three piece speedometer cable
My 1979 Silverado has factory cruise control and what I can only describe as a three piece speedometer cable. There is a short section that runs from the tranmission to the "middle" piece. The middle piece is the longest and is pressed into a metal bracket to guide it up around exhaust and to the cruise control unit on the driver's side inner fender. The last piece runs from the cruise control unit to the instrument cluster. The middle piece needs replacing and I can't find anything new from the usual places. Any suggestions?
thumpernickle is offline   Reply With Quote
Old 10-26-2014, 07:57 AM   #2
jjzepplin
jjzepplin's Avatar
Re: Three piece speedometer cable
Is it the housing that is bad or just the inner cable? Autozone has an inner cable replacement piece that I am going to try out soon as I have a super long speedo cable and my speedo jumps. I think it is the cable.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-26-2014, 04:16 PM   #3
Axle
Axle's Avatar
If you have no luck finding what you need, might want to convert to a 1 peice lower cable. My '81 has a one piece cable to the transducer (63"). Search speedometer cable on rockauto, look at trucks, late 70's, early 80's monte carlos as well, and any other fullsize car until you find a cable that is suitable.
Alex.
Axle is offline   Reply With Quote
Old 10-26-2014, 04:58 PM   #4
Just call me Sean
Just call me Sean's Avatar
They always give me that universal cable at AutoZone, and so far it has worked every time. It is just the inner though. Cut to length and stamp an end on it.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 10-26-2014, 05:02 PM   #5
thumpernickle
Thanks for the suggestions. As far as I can tell, it is just the cable, so I will try a universal cable and cut it to length.
Old 10-27-2014, 03:56 PM   #6
mrolds88
One other thing to think about is why and how did the last cable go bad. Did it simply twist into a point? Or did it fray? Did it scar the inside of the cable housing? If it scarred the housing, you will more than likely have issues again.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Thread Tools
Display Modes
