11-02-2014, 02:35 PM | #1 |
limited slip in a stock 12 bolt rear end
Can Anyone guide me in converting my open 12 bolt 3:73 from my 67 2wd to a limited slip? Is there a rearend from another veh. That i can use the limited slip mechanism from?
1967custom |
11-02-2014, 03:27 PM | #2 |
Lurky lurky
Re: limited slip in a stock 12 bolt rear end
The truck and car 12 bolts were totally different, the cars have a round diff cover and the trucks the oblong shape you'll see under yours. So you'll need to source one for a truck, not a car. You can search around for an original no-slip differential and swap it into yours or an entire housing swap might be easier.
If you pull the chunk out (ring gear and diff) to put in a posi unit you'll probably open a can of worms. Reshimming the backlash and pinion to ring gear depth with a different (either new or used) is a pretty precise operation. Not impossible but a pretty major task. |
11-02-2014, 04:53 PM | #3 |
drive it into a shop drop it off with the thousand or so dollars and pick it up and drive it home in a few days is the simple foolsproof way to do it
11-02-2014, 07:34 PM | #4 |
Cdowns. Funny $$$$$
Ill have to look and find a truck 12 bolt setup then. Ive never swapped internals before
1967custom |
11-02-2014, 07:38 PM | #5 |
Lurky lurky
Yep, typical 4x4 shop is a good place to try. They'll have a differential tech most likely since the off road guys need locker and gear updates when they get going. My last gear and posi swap was with a 2006 Sierra, went from open 3.08 to Trutrac and 3.73s, set me back $800 total. I "know how" and have done it in the past but it's worth it paying someone else to smell like diff fluid and fight the shims, backlash, and weight of the center section in and out.
11-03-2014, 12:10 AM | #6 |
here is an option you wont have to remove ring and pinion or reset the axle shims. just replace your spider gears for this unit. http://www.summitracing.com/parts/pw...3005/overview/
11-03-2014, 01:32 AM | #7 |
If you want to keep your 3.73 gearing and your gears are fine then all you need to do is get a 4 series posi carrier, new gear oil+limited slip additive, and new gasket and your set.
Pull the diff cover, pull the bolt out that locks the pin through your open carrier then press the axle shaft as far as you can inwards towards the center of the vehicle, pull the c clips out (if they didn't fall out already), pull the axle shafts out or out far enough so they are not in the carrier, undo side bearing caps, pull open carrier out of your housing, in bolt the ring gear from your open carrier and bolt it onto your posi carrier, (best to make your ring gear warm and the posi carrier colder then the ring gear so it slides over nicer) tourque down the ring gear bolts to specified torque, install new side bearings if needed to posi carrier, install posi carrier with the original side shims used with your open carrier (be sure to put the one that was on the left back to the left side and right one back to the right side) reinstall bearing caps and torque bolts to specified torque, then slide your axle shafts in as far as you can again (must take the pin out if the posi carrier) reinstall the c clips and slide axle shafts out as far as you can, install the pin into the posi carrier and torque down the bolt that secures it to specified torque, then you can check your back lash and how the teeth mesh together with gear marking compound if it's within specs then your ready to bolt the diff cover on with new sealant or gasket and fill with right amount gear oil and limited slip additive. Your rear tires must be the exact same size and have same amount of wear of tread, if they are off in size in any way from each other you will cause a lot of stress on the clutch packs! |
11-03-2014, 02:06 PM | #8 | |
11-03-2014, 02:08 PM | #9 |
70+ ( Old Skool Club )
This is one thing i let the pros play with !!!!
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
11-03-2014, 05:16 PM | #10 |
Rebuilding a diff is much simpler than rebuilding an engine, yet it is the one part of these trucks that is treated as though you must be an expert at witchcraft, arcane black magic or voodoo to even touch one. It has 2 carrier bearings, a center carrier with a ring gear bolted to it and the bearings pressed on the ends of the carrier and a pinion gear with a pressed on bearing. Left side and right side shims to set the backlash and pinion shims to set pinion depth and the pinion nut to preload the pinion bearing. That's it. No more.
That's not complicated. If you can read the overhaul manual and use a dial indicator rebuilding one is easier than installing a new water pump. It took me 30 minutes to tear mine down, replace the open carrier with an Eaton Posi unit and switch the gearset from 3.73 to 4.10 and reassemble it. That diff now has 10,000 miles on it without a whine or whimper. Total parts cost for all new pieces except the pinion nut and the carrier bearing caps was $700.00. Western gear wanted $1400.00 to do the same but I had to accept the "parts they preferred" not the premium pieces I used. Tucson Differential was $1500.00 and the owner told me if he had to use the Richmond Gear gearset and Eaton center section I wanted the cost would be over $2000.00 So I spent the $700.00 kept a minimium of $700.00 more in my checking account and got the parts I wanted instead of the "made in China" stuff they usually use. Last edited by Fitz; 11-03-2014 at 05:32 PM. |
11-03-2014, 07:24 PM | #11 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by hdff; 11-03-2014 at 07:30 PM. |
11-03-2014, 09:41 PM | #12 | |
11-03-2014, 10:01 PM | #13 | |
http://www.summitracing.com/parts/dtl-913a315/overview/ Follow Fitz's instructions. If your gears run quiet now, and you duplicate your backlash measurement (provided it's within .005-.012") as it is now and get a good pattern, this will be a piece of CAKE. Pull a pattern BEFORE you remove the old carrier; this will give you an idea if you need to make an adjustment on the first install. You won't even need to pull the pinion, but a good time to check pinion bearing pre-load while the carrier is OUT. If it needs tightened, use an impact gun on the nut until you get a little drag. Then if you want to put a new seal on the pinion, mark the nut where it aligns with the pinion shaft with a chisel, replace the seal and simply tighten the pinion nut back to the mark. Installing new side bearings and using the old shims you will likely hit the mark the first time and also have good pre-load but you still might have to play with shims some if your backlash was out to lunch or pinion depth off. Like I said, if it's set up right now, it's real easy to duplicate. If you can turn the wrenches, we can supply the experience. Last edited by mechanicalman; 11-03-2014 at 10:04 PM. Reason: wrong part |
11-03-2014, 11:21 PM | #14 | |
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
11-03-2014, 11:53 PM | #15 |
11-03-2014, 11:58 PM | #16 | |
You left out the ONE BIG STEP that will spell doom on setting up a diff. Always, after you tighten the last bolt and fill it with oil, you must say "ooga booga wooga mooga" or the diff will die, each and every time. Shame on you! Ask me how I know LOL |
11-04-2014, 01:26 PM | #17 | |
With no overdrive and a 3.73 gearset the engine is at 3200 RPM @ 70 MPH. With the overdrive and 4.11 gearset I'm turning 2378 RPM at 70 MPH. This gives the launch and high acceleration of the 4.11 in first and second yet it acts like a 2.73 in overdrive. This combo is the best of both worlds for me. |
11-04-2014, 01:29 PM | #18 | |
Way to go, Mechanicalman! |
11-04-2014, 01:37 PM | #19 | |
11-04-2014, 09:58 PM | #20 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
11-05-2014, 09:38 AM | #21 |
11-15-2014, 04:46 PM | #22 |
i would bother trying to find a unit from another axle to put in your alot better off spending the 600 on a brand new unit than get one thats going to be worn and who knows its history
11-15-2014, 07:56 PM | #23 |
I've regeared many axles back in my rockcrawlin days. The hardest part of setting up axle gears is getting the pinion depth correct. This has to be set correctly before any side bearing shimming can be done. Since you will be using your original gears the pinion depth is already set so you just have to change the carrier and check your pattern, if any adjustment is needed it will only be side bearing shims.
The trick to setting up axles easily is to buy another set of bearing and grind the I.D. out a couple thousands then you can remove the bearings easily to do shim changes. Once you get the shims right press on new bearings with the shims and your good to go.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
Thread Tools | |
Display Modes | |
