Old 11-04-2014, 01:47 PM   #1
asbill71
Drop Spindle question
I have a stock height 65 Suburban. 6 lug all the way around. I want to stay six lug, but want front disk. I have been scouting for 73-87 donor trucks to grab the control arms and spindles. But I also plan on getting drop spindles and springs. Here is my question. Is there a drawback to just ordering the "Conversion" spindles that bolt directly to my existing ball joints and tie rods? Then just buying rotors, calipers, brake lines at the parts store. I probably would have replaced the ones from a donor truck if I went that route. Except for rounding up small parts, ie washers and caliper bolts, wouldn't this route be cheaper since I plan on drop spindles anyways?
asbill71 is offline   Reply With Quote
Old 11-04-2014, 01:54 PM   #2
CRGRS 66
CRGRS 66's Avatar
Re: Drop Spindle question
I never went to all the research on whether I could have saved a few dollars, just bought a kit from CPP, kit included everything including calipers, dust sheilds, bearings, calipers, spindles, and so on. It was worth it to me not have to be scrounging around for odd hardware that may not have been included when buying individual parts.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 11-04-2014, 03:01 PM   #3
NEWFISHER
NEWFISHER's Avatar
They used to offer drlpped spindle disc or drum kits with 6 lug. Ill try to find a link.
Edit
Found them
http://m.ebay.com/itm/330946117099?cmd=VIDESC&gxo=true
Or Ecklers
http://www.ecklerstrucks.com/chevy-t...1963-1970.html
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 11-04-2014, 03:51 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
you will also need to change the Master Cylinder!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-04-2014, 03:53 PM   #5
PGSigns
PGSigns's Avatar
I have done it on both my trucks using the donor route. I rebuilt the front components and swapped them in. I added drop springs and drop spindles, the rotors you have to get aftermarket to stay 6 lug. Summit racing had the best price and service. Gave me everything I needed and came out good.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-04-2014, 07:51 PM   #6
cori 64
cori 64's Avatar
I did all the research i could take "MY HEAD WAS STARTING TO HURT"and i just went with mcgaughy 2.5 drop spindle kit with everything! Everything bolted right up no problems!!,and i dont know how but i got lucky with my original 6 lug steel wheels clearing the calipers!!!!!!!!!!And they came off my 61 gmc!!! ....I did however change the tiny U bolts on the lower A arms that is a MUST!!!! and of course the master cylinder
cori 64 is offline   Reply With Quote
Old 11-06-2014, 01:25 PM   #7
Nacho_Paras N.L.
I used this kit from CPP... I bought the upgraded version about 4 yrs. ago and at that time they offered the master cylinder with the kit.. This kit is great.. You have the option to keep 6 lugs or convert to 5.. i converted and chose 2.5 drop spindles.
Nacho_Paras N.L. is offline   Reply With Quote
Old 11-06-2014, 05:00 PM   #8
CRGRS 66
CRGRS 66's Avatar
That is the kit I bought from CPP, I went 6 lug, and 2.5" spindles, ordered the booster/MC/prop valve separately as kit from CPP as well.
Craigerrr
Old 11-06-2014, 05:25 PM   #9
firemanjimtfd
firemanjimtfd's Avatar
CPP runs a lot of specials on Ebay . Also if you have CPP part numbers order from Summit its free shipping if you spend $100. CPP wanted about $100 to ship drop spindle kit and power booster combo.
firemanjimtfd is offline   Reply With Quote
Old 11-07-2014, 04:00 PM   #10
wildearp
wildearp's Avatar
If you call CPP with the Ebay auction/sale number, CPP will usually honor the price shown and you can buy direct without any ebay nonsense. Those deals are great and they usually throw in $150 extra stuff on a complete front end.
To the original question, from what I was gathering info on, there are somewhere around at least three different ball joint sizes for the various years of trucks. I don't know if tie rod sizes changed. I can see how it could easily be a confusing mess when ordering spindles.
I just ordered the complete Fatman front end. It has several advantages, with tubular a-arms and better ground clearance, while still being a completely bolt on kit. I am still about two weeks out on delivery, and then you will see a build thread.
wildearp is offline   Reply With Quote
Old 11-07-2014, 10:43 PM   #11
xRAY76
is there any real benefit of staying with 6 lug over converting to 5 lug?
or is it only wheel preference?
xRAY76 is offline   Reply With Quote
Old 11-07-2014, 11:16 PM   #12
Cooper197
Cooper197's Avatar
I did a McGaughy drop spindle kit on my truck from Summit. They offer 5 and 6 lug, and you don't need to change the master cylinder if you don't want to! The McGaughy kit is made to work with wheels as small as 15" I believe, so clearance shouldn't be an issue with it either. It wasn't that bad on pricing, $649 shipped and that included my rear springs, so probably about $550 for the brake/spindle kit
Cooper197 is offline   Reply With Quote
Old 11-08-2014, 02:06 AM   #13
Grizz1963
Grizz1963's Avatar
Another one of those questions that have me wondering about stuff.
I have a standard front end with 6 lug and drums up front, after redoing my suspension with 2" drop all the way around, I am now thinking that I want the front end a bit lower still.......... See here: http://67-72chevytrucks.com/vboard/s...585901&page=24
So can I do it while keeping everything else in place without sacrificing ride quality and use ability?
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 11-08-2014, 12:32 PM   #14
CRGRS 66
CRGRS 66's Avatar
Hey Rian! Not sure how I missed your build thread before, but I am subscribed now.
I can't answer the question, and someone may have the answer for you, but may I suggest that you contact CPP, or the like by email to see if their drop spindles will accept your drum spindles?
Craigerrr
Thread Tools
Display Modes
