Old 11-07-2014, 12:10 AM   #1
greywurm
Glowing red header tubes
I've posted a couple questions over the last month or so as I've been swapping in a 72 350 in my 71 long bed and everyone's help has been great.
Got the truck back from the muffler shop today - installed 2.5" dual pipes with black widow mufflers. Sounds GREAT.
Anyways, it was dark out and I knew I needed to do some tuning, and I was too anxious to wait so I figured just dive right in. And glad I decided not to wait because I might not have noticed as quickly what I saw if during the day...
Header tubes for #1,#3,#6 and #8 glowing bright red in the dark... a little off colored under light, and a little smell. Not sure how i'd describe it but I think its just from the grease that rubbed off my hands burning off.
I was originally planning on messing with the fuel because it would stall out under load and I've read that the edelbrock carbs dont like too much pressure. I'm not sure if its related, but if its getting too much pressure and is flooding the carb, couldn't it cause a rich mixture and potentially detonate after it leaves the exhaust port?
Disconnected the timing advance on the HEI and yep, my timing was a little retarted... 4 degrees after. Set it to 4 degrees before, but I didn't notice a decrease in the glow. Maybe I was impatient and should reconnect the advance and check for glow again, but it was getting late so I didn't was to upset the neighbors anymore.
What else should I be thinking of checking? My gut is telling me its timing since its 2 cylinders on each side of the motor, not all on one side, so I don't think the headers are clogged. They came with the motor, so they are used and I installed them myself. Maybe not a good job?
I am lacking the inner bolts to the outer tubes because I cant get either header bolt design I have to clear the elbow of the tube to go in the heads, so I could have a poor seal letting air in for detonation in the tube... But being that its also happening on #3 and #6 where I do have bolts, I am currently ruling that out, for now.
I did notice occasional flames out of a couple exhaust ports when I did a test run of the engine on the stand to make sure it would run (only for ~ 10 seconds each time). I didn't think much of it at the time, but if it is timing, then I was 4 degrees after then as well.
What do you guys think?
71 Long bed C10 w/68 front clip, 350 SBC+HEI, TH350
06 Yukon XL Denali - Stock
greywurm is offline   Reply With Quote
Old 11-07-2014, 12:13 AM   #2
greywurm
Re: Glowing red header tubes
Here's a pic of each side
Old 11-07-2014, 12:26 AM   #3
geezer#99
geezer#99's Avatar
Lean and retarded timing does that.
You've only got 4 degrees initial.
You should be at 12 to 14 or more depending on your cam.
Old 11-07-2014, 12:28 AM   #4
greywurm
Is that 12 to 14 before without advance connected? I thought it was 4 without advance.
I'm pretty sure its a stock cam, but I dont really know.
Old 11-07-2014, 12:37 AM   #5
geezer#99
geezer#99's Avatar
Yup!!
12 to 14 btdc.
Set with vac advance plugged off.
More timing will speed up your motor so you might need to turn the idle back down and re-adjust your mix screws.
Old 11-07-2014, 01:50 PM   #6
greywurm
Ok. Whats the correct idle rpm?
Edelbrock performer 600 series carb and i think an edelbrock intake if it matters.
Old 11-07-2014, 02:13 PM   #7
junksaver
I think you have a lean condition. Set your timing 1st 10-12 degrees. Then you need to adjust the idle mixture screws. If you have access to a vacuum gauge you can adjust them for the highest vacuum. Also adjust the screws in one at a time while it is running. If the idle doesn't change you may have trash in the idle circuit of the carb. You can also Google adjusting edelbrock carbs and get more information.
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 11-07-2014, 02:38 PM   #8
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
The primary metering rods, jets and springs must be tuned to your specific engine, altitude etc. I called Edelbrock and explained all my specifics; engine size, trans, gear, and my climate conditions (for me low altitude and hot) and the tech was able to tell me what I needed to start with. After I set the carb up as he instructed I went theough the timing and mixture processes and the carb ran like a dream. Give them a call, they have excellent customer service.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 11-07-2014, 07:12 PM   #9
Tree-50
My 350 says 700rpm at idle.
Tree-50 is offline   Reply With Quote
Thread Tools
Display Modes
