11-09-2014, 08:30 PM | #1 |
Headlights not working--help needed
Everything works except for the headlights. Even bought a new switch and still the same. Parking lights work but no headlights. No power to the plug at the core support leading to the headlights. Very strange. Any suggestions? Turn signals, interior light, brake lights, horn; all work! No blown fuses. Grounding issue maybe under the dash? Hopefully someone can point me in the right area. Thanks
11-09-2014, 08:42 PM | #2 |
Re: Headlights not working--help needed
Check at your dimmer switch plug or dimmer switch had same problem once sanded connector and prong hope this works for you
11-09-2014, 11:41 PM | #3 |
Wiggle the plug at the firewall.
11-10-2014, 07:49 AM | #4 |
11-10-2014, 07:22 PM | #5 |
Who Me?
I would look there too.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
11-10-2014, 09:00 PM | #6 |
I was at a cruise in a couple of weeks ago that ended after dark. I started up, turned on the lights and started to pull into the highway when I realized that I had no lights. Panic time, 30 miles from home. I backed up into my parking spot to look for loose wires, fuses, etc. A guy a couple of cars down shouted "Try your dimmer switch!". Hit the switch and the lights came on, problem solved. Give it a try. Brights and dims go thru the switch.
11-10-2014, 09:24 PM | #7 |
not trying to thread-jack the OP...
is this a common problem for these trucks? i have a 60 c10 and have no headlights, everything else works, even the bright lights. i have replaced the dimmer switch, checked both headlights on a battery, and replaced the pig tails...nothing |
11-11-2014, 11:13 PM | #8 |
One more for dimmer switch! Both low and high beams run trough that switch.
Pull the plug and check to see if it's loose or dirty. If not, eliminate the switch by jumpering the wires at the plug. CaREFULLY. Three wires going into your switch Blue , that's the supply from your light switch. Tan , low beam Green , high beam Use alligator clips or wire (stripped back just enough to go into the plug) to jump the blue and tan wires together. Now pull on your light switch. If your lights come on, it's your dimmer switch. I'd bet money that's what it is, but not real money. I ain't got none! |
11-12-2014, 09:00 AM | #9 |
Thanks guys for all the help. I bought a new switch. Going to install it this weekend along with my CPP lowering kit. Going to be a busy weekend
11-12-2014, 11:05 AM | #10 |
Moderator
I'm in the same boat, everything works, except headlights. Probably the dimmer, I haven't done the trouble shooting yet. Common enough, I suppose.
11-16-2014, 09:03 AM | #11 |
It was the dimmer switch. Headlights are now working. Now I just need to figure out why my front left turn signal comes on when I hit the brakes. Turn signals work fine. Any suggestions? Maybe cleaning the sockets and bulbs?
11-16-2014, 03:38 PM | #12 |
problem is in the turn switch it needs some TLC
11-16-2014, 07:41 PM | #13 |
Bad grounds....All kinds of uuexplainable stuff happens when you have a bad ground somewhere. Ground all of your light sockets.
Thread Tools | |
Display Modes | |
