Old 11-10-2014, 03:18 PM   #1
Tarc
Will wheels fit 1969 c10 drum brakes 2/4 drop
Hello all
I was wondering if wheels which have a backspace of 3.75 (offset -19mm) would fit on a 1969 c10 with stock drums and a 2/4 drop (which shouldnt really make a difference)?
http://www.performanceplustire.com/b...heel?size=15x8
Thanks in advance.
T
Tarc is offline   Reply With Quote
Old 11-10-2014, 08:41 PM   #2
Mike C
Mike C's Avatar
Re: Will wheels fit 1969 c10 drum brakes 2/4 drop
What width rim and tire size? It should fit no problem on a 7 or 8 inch wheel I would think.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-11-2014, 08:03 AM   #3
Tarc
I was thinking 15x8. I like my stock steel (15x7 I believe) but don't want to under buy and wish I could put a wider wheel later. Thanks for the reply mike!
Old 11-11-2014, 07:41 PM   #4
Mike C
Mike C's Avatar
What size tire are you going to run? Buying wheels that fit the tire is the right way to go. Places like Tire Rack will list the specs and the minimum/maximum recommended rim width for the tire. Pick one in the middle!
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 11-12-2014, 06:35 PM   #5
Tarc
I was thinking something like a 255/70/15 tire size.
The specs on that wheel are 15x9 6x5.5 with 3.75 backspace. Seems like it should work? Maybe a little taller on the back. To be honest I am installing the 2/4 drop this weekend and curious to see how it sits given current spring age.
Thanks again for the responses! It's very much appreciated.
Thread Tools
Display Modes
