Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 11-11-2014, 11:34 PM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
WTB - Complete Hydroboost
Looking for Hydroboost setup.
Complete or parts.
66 C20 Service Truck:
Old 11-12-2014, 12:37 AM   #2
396ci
396ci's Avatar
Re: WTB - Complete Hydroboost
i have a complete hydroboost from a 77 dually. its still in a running truck so let me know how complete you need it and i will get you a price with shipping. example: do you need things like the brake pedal assembly and power steering pump/brackets or just the firewall brackets/hydro unit/ and hoses (any bolts associated with this will be included). the system works but leaks between the hydro and master cylinder because i forgot to install the o-ring. master cylinder is new(ish). will send you some pics tomorrow night. thanks
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline   Reply With Quote
Old 11-12-2014, 02:09 AM   #3
LostMy65
LostMy65's Avatar
Probably going to need all of it.
I don't have anything but manual brakes & steering at this time. I'll try and get the power steering box local - I expect shipping on the heavy ps box would make it out of my price range.
But yes, I need pretty much a complete setup.
Thanks,
Robert
Old 11-12-2014, 10:55 PM   #4
74CustomK20
74CustomK20's Avatar
Depend on size could you use a flat-rate box from usps?
74CustomK20 is offline   Reply With Quote
Old 11-12-2014, 11:05 PM   #5
LostMy65
LostMy65's Avatar
Yes, I was able to fit a 79 4x4 power steering box in a usps large flat rate box.
Old 11-12-2014, 11:13 PM   #6
396ci
396ci's Avatar
sorry for the crappy pics. total with shipping would be $350 which would include:
hydroboost/master cylinder/prop valve w lines to mc/all hoses to ps/ps pump and brackets+bolts/ps pump belt/ps box+bolts. will be shipped in 2 boxes to prevent damage. if you dont want the ps box then subtract $125.00. the only thing to check would be that this would work with your current brake pedal set up. could include the pedal set up from this truck for an additional $60 shipped (likely a third box). thanks for your time.
Brian
XNGH ECV Chapter 58
Old 11-12-2014, 11:38 PM   #7
LostMy65
LostMy65's Avatar
Do you know if the power steering pump has the 3 ports, or does it use a T-Fitting?
Old 11-12-2014, 11:55 PM   #8
396ci
396ci's Avatar
i can check that tomorrow and let you know.
Brian
XNGH ECV Chapter 58
Old 11-13-2014, 08:41 AM   #9
LostMy65
LostMy65's Avatar
You know what?..... It really doesn't matter whether it has the T-Fitting or 3rd port.
If you're including everything that has to do with the whole hydroboost and power steering system - hoses, brackets, and such - and you're comfortable that it's in good working condition, I'll take it.
If you could take me a pic of the pedal assembly where it mounts to the rod for the booster, I may want that also.
Thanks.
Old 11-13-2014, 09:10 AM   #10
faribran
I have been thinking of doing this setup for a while. Good move. Let us know when you get this in place and how well it works.
faribran is offline   Reply With Quote
Old 11-13-2014, 03:08 PM   #11
396ci
396ci's Avatar
Thanks.
i know it works and i know it leaks. not trying to kill my own sale but consider this option: check with the local autozone in oregon city for the majority of the hard components. these are the prices for reman items:
hydroboost $155.99
master cylinder $19.99
power steering pump $39.99
power steering box $126.99
high pressure ps hose $17.99
return ps hose $11.99
so for $$372.94 you get new parts and now you only have to come up with some brackets for the power steering, a proportioning valve with lines to mc, and hoses from hydro to power steering and maybe the pedal assembly.
just something to think about. thanks
Brian
XNGH ECV Chapter 58
Old 11-13-2014, 09:30 PM   #12
LostMy65
LostMy65's Avatar
I appreciate your upfront honesty.
I did look at the cost for new when I first saw your price of $350.
But I then considered how you're including everything I need for the conversion.
Saving me the time of tracking down all the components.
On the other hand, getting all new gives me a little more security.
I'm going to do some more research.
Old 11-13-2014, 09:38 PM   #13
LostMy65
LostMy65's Avatar
Oh, and another thing. ...
Most the pieces new at an Auto parts store also have a core charge.
Old 11-13-2014, 09:49 PM   #14
396ci
396ci's Avatar
good point! i think for the extra money for new parts and core charge you are getting peace of mind. then at least you are only tracking down common stuff (like ps brackets and maybe the pedal assembly). im sure you can get hydroboost hoses too. good luck with your project! i didnt get a chance to snap a pick of the pedals where the hydroboost attaches but i will do that for your. i only brought that point up because on the 4 speed pedals it does matter whether the booster is hydro or vacuum.
Brian
XNGH ECV Chapter 58
Old 11-13-2014, 10:35 PM   #15
LostMy65
LostMy65's Avatar
Originally Posted by 396ci View Post
good point! i think for the extra money for new parts and core charge you are getting peace of mind. then at least you are only tracking down common stuff (like ps brackets and maybe the pedal assembly). im sure you can get hydroboost hoses too. good luck with your project! .
I agree.
Thanks!
No problem.
Old 11-16-2014, 06:41 PM   #16
LostMy65
LostMy65's Avatar
I've totalled up the pricing to put this together, along with the core charge, and I'm still interested in getting the whole package from you. If any of your components need rebuilding, I think it still will be the easier route, rather than trying to track down all the parts along with all the bits and pieces.
Let me know...
Thanks,
Robert
Old 11-16-2014, 10:51 PM   #17
396ci
396ci's Avatar
Let me know...
Thanks,
Robert
hi robert, the parts are yours. i will pm some info to you. thanks, brian
Brian
XNGH ECV Chapter 58
Old 09-06-2015, 10:10 PM   #18
LostMy65
LostMy65's Avatar
I'm sure you got busy.
Did we ever get going on this?
-Robert
Old 09-07-2015, 12:38 AM   #19
396ci
396ci's Avatar
-Robert
its ready for you. just let me know on the power steering box and whether or not you need the brake pedal assy. thanks.
Brian
XNGH ECV Chapter 58
Old 09-07-2015, 05:29 AM   #20
LostMy65
LostMy65's Avatar
I'll take everything but the ps box and pedal assembly.
Private message me your PayPal info and I'll send you the $225 and my shipping address.
Old 09-07-2015, 10:50 AM   #21
396ci
396ci's Avatar
pm sent. thank you.
Brian
XNGH ECV Chapter 58
Old 09-07-2015, 09:27 PM   #22
LostMy65
LostMy65's Avatar
Payment Sent.
Old 09-07-2015, 09:41 PM   #23
396ci
396ci's Avatar
Payment Sent.
thanks robert. i will try and ship this out tomorrow but it might be wednesday. i will pm you the tracking number.
Brian
XNGH ECV Chapter 58
Old 09-07-2015, 09:50 PM   #24
LostMy65
LostMy65's Avatar
That works.
I did want to make sure you could also send the rod coming out the back of the hydroboost. The part that connects to the pedal.
Old 09-07-2015, 09:52 PM   #25
396ci
396ci's Avatar
yes, its on there. funny thing is i am coming to clackamas on sunday for business. will be there all week, maybe i could buy you lunch?
Brian
XNGH ECV Chapter 58
Thread Tools
Display Modes
