1948 Bed pics and Questions
Well I decided to unbox all my new bed parts and do a mock up to see what it looks like. The truck is starting to take shape slowly. Anyhow, after moving the rear end back a little it still looks like about 2 more inches to center the rear wheel better.
My question is, this is a stock 3600 chassis and when I put the bed on with my Ford Explorer rear end, I had to run a 1.5" wheel spacer to clear the bed. Luckily I had a set of these sitting around. Has anyone else run into this? I am also toying with cutting sides to install a wheel well on the side so that I have no issues once it is done. I do have 10" wide rims on the back but even when I mocked up the 8" front on the back it still looked close. Anyhow looking for thoughts and ideas. It is all on the joy of doing a build. ![]()
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end. ![]() http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670 Last edited by J48chevy; 11-14-2014 at 06:10 PM. |
Re: 1948 Bed pics and Questions
One more pic.
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end. ![]() http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670 |
Pic of issue. Hard to see but tire is less than finger width away from bedside and that is with 1.5" wheel spacers installed.
Also, anyone have a link showing bed mount instructions? The 2nd pic will show I bought a rubber bed mount kit but still seems to angle down a little.
Inside shot of bed.
You are right, the axle needs to go back a bit and probably close to 2 inches but what I would do is figure out exactly where I wanted the wheel centered and not be hung up on an exact measurement. Get it so it looks perfect in your eyes and nail it down.
You might be able the 8s but it will be close. I ran 10s on my '54 but needed a 2" tub for good clearance. If it where me I would add a 3/4" to 1" spacer to raise the front of the bed a little.
Rob
My '47 C.O.E build |
Is the bed in the correct location? From the pics it looks like there more than normal space between the front panel and the cab. If it could move forward it would center the wheels better.
It should be. Lined it up with holes in frame. Front cross will only had one set of holes in frame. Will have to measure between cab and box. Plus no way to move forward as the front edge of fenders are right at the running boards too.
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end. ![]() http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670 Last edited by J48chevy; 11-15-2014 at 09:07 AM. |
![]() Join Date: Jan 2009
The explorer 8.8 is def a squeeze. I'm running spacers 1.5" with 8" wide rears, they still rub just a bit on turns.
Not sure how far you've already moved the axle back, but as was stated already, just line it by what looks good to you and don't stress much over the numbers.
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
Thanks for pic. Truck looks awesome. What blocks or spacers did you use under cross sills to get the level height? I bought the poly blocks but looks like I will need to add some to get the right level height. Also, what is the measurement from the lip below the back window to top of front part of the bed. This will give me an idea on how close or far off I am.
#12 | |
#13 |
All I know is your garage is too friggin nice, I don't even want to talk to you!
It's cool seeing a 3/4 ton done, very cool. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#14 |
Haha. Thanks. I actually think it is a mess right now. All I know is that I need a bigger garage because I have way too many toys.
#15 |
where in michigan are you? i'm in northville/novi area
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#16 |
I live in the Saginaw/Caro area. Not too far away.
Thread Tools | |
Display Modes | |
