11-25-2014, 09:35 AM | #1 |
drop spindle capabilities.
Hello out there.
I really enjoy reading all they great forums for repairs and projects. I get some great information and ideas from all you out here. I have a project of my own on the way and would like some info on the front spindles. First off My truck is a 1980 GMC 2wd 3/4 crew cab very very clean start only 80 thousand km with not rust what so ever. I have shortened it for my short box now I am about to order a drop kit for it. I am only going 4 Front 5 Back. Bell tech has a kit 967ND for a 1 ton truck.I cant find one for my 3/4 ton. I am with the understanding that the front spindles are the same between the two trucks.I don't have a 1 ton dually to compare the two was hoping someone here would know if this kit will work for my truck. Thanks for any help you can provide and I will try and post some pics. |
11-25-2014, 05:29 PM | #2 |
Re: drop spindle capabilities.
When you get into suspension the 3/4 and 1 ton should be the same. The main difference between the 2 should be the drive train for towing capabilities.
11-25-2014, 06:21 PM | #3 |
Use C30 drop spindles, and calipers. C20 use different calipers, but both use hr same rotor.
11-25-2014, 07:43 PM | #4 |
https://www.performanceonline.com/71...e-2-half-inch/
Use all your stock brakes. They are expensive though. Airbaggit/AIM/Chassis Tech makes a shackle and hanger kit. I normally wouldn't recommend their stuff but the kit I have looks fine.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Thread Tools | |
Display Modes | |
