Old 11-26-2014, 07:56 PM   #1
GMtrucknut!!
GMtrucknut!!'s Avatar
Wire loom question / opinion
I have purchased an American Autowire complete update harness and really want some high quality loom for the wires which are exposed under the cab and bed . I don't want the split loom cheap stuff as I don't like the look or the performance of it. Please give me some ideas and good places to procure the best quality product.
GMtrucknut!! is offline   Reply With Quote
Old 11-26-2014, 08:17 PM   #2
1project2many
Re: Wire loom question / opinion
All split loom is not made alike. Nylon and polypropylene last much longer and can handle higher temperature. You can also get braided loom which is harder to run wires through but looks a little more appropriate under the hood imo. Heat shrink fabric loom looks closer to original but costs plenty more. And there's always reproduction asphalt cloth loom for a truly vintage look.
1project2many is offline   Reply With Quote
Old 11-26-2014, 08:31 PM   #3
GMtrucknut!!
I have seen unsplit industrial loom that had locking ends installed but have no idea where to get it. The reproduction asphalt will look out of place on my truck as it has been modified .
Old 11-26-2014, 09:30 PM   #4
FiftyTwo
FiftyTwo's Avatar
I used a good quality split loom and insulated clamps up inside the frame rails out of sight. If there's ever a problem with the wiring I can easily slip the wires out of the loom and check them out. Can't do that when you wrap them all up or use some kind of covering. NAPA sells the good stuff in different sizes by the foot.
http://www.napaonline.com/Catalog/Ca...520_0063685816
If your doing a full restoration, then you'd want something more period correct.
FiftyTwo is offline   Reply With Quote
Old 11-26-2014, 09:56 PM   #5
OrrieG
OrrieG's Avatar
I used a product similar to this purchased off of Ebay. In some areas where I had a lot of wires spliting off I used the black poly spiral. Before I used the split ribbed stuff but it is a PITA to keep clean.
OrrieG is offline   Reply With Quote
Old 11-26-2014, 09:58 PM   #6
dfrank
dfrank's Avatar
I the braided stuff from summit. Pretty pricey but looks mighty good.
dfrank is offline   Reply With Quote
Old 11-26-2014, 10:00 PM   #7
_Ogre
_Ogre's Avatar
why not wrap the wire harness?
shop air compressor timer
Old 11-26-2014, 10:01 PM   #8
_Ogre
_Ogre's Avatar
ofdah, big ash picture
Old 11-26-2014, 10:18 PM   #9
1project2many
Google is your friend. Start with images and go from there:
https://www.google.com/search?q=wiri...ch&q=wire+loom
Or
https://www.google.com/search?q=wiri...osed+wire+loom
Non-split loom:
http://www.cabletiesandmore.com/nonSlitWireLoom.php
Here's some neat stuff:
http://www.elecdirect.com/catalog/tu...d-tight-tubing
How about Smooth split tubing:
http://www.flexiblepvc.net/Flexible_...ing-smooth.htm
Old 11-27-2014, 04:20 PM   #10
crossfire84
crossfire84's Avatar
wow i could rap a fleet of semi's with that roll!
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 11-27-2014, 06:17 PM   #11
OrrieG
OrrieG's Avatar
Not with no-name generic tape, will crack and unravel. Use UL listed for gas-oil environment.
Old 11-27-2014, 09:13 PM   #12
Russell Ashley
Russell Ashley's Avatar
If you want to wrap the harness with black wrap the correct material is available. You might have to search for it but it is not tape. It seems to be thicker and it is not sticky like tape. Like OrrieG said, typical black electrical tape that you commonly find is not suitable to use where it is subjected to high temperature, like under the hood.
Russell Ashley is offline   Reply With Quote
Old 11-28-2014, 07:18 PM   #13
Iceburgh
Iceburgh's Avatar
If you like the look of the sleeving ( I do) the cheapest place is grainger
http://www.grainger.com/search?nls_o...=wire+sleeving
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 12-06-2014, 05:50 PM   #14
Russell Ashley
Not as difficult to find as I thought.
http://www.ebay.com/itm/1-Roll-Facto...63c9c8&vxp=mtr
Old 12-06-2014, 07:51 PM   #15
1project2many
That tape is actually called "non adhesive harness tape." It's also available in cloth if your harness is old enough to need it.
Old 12-06-2014, 11:03 PM   #16
roger55
roger55's Avatar
I buy split loom from http://www.waytekwire.com.
Everything they carry is high quality and the prices are good too.
roger55 is offline   Reply With Quote
Old 07-16-2016, 05:13 PM   #17
IdahoMan
Super 88 tape electrical tape. How's it for gas-oil environment, anyone used it?
IdahoMan is offline   Reply With Quote
Old 07-16-2016, 05:26 PM   #18
roger55
roger55's Avatar
I've used it.
Good for weather but not oil or gas.
I don't know of any adhesive electrical tape that would hold up to oil or gas,
Adhesive lined heat-shrink tubing would be oil resistant I would think. I doubt it would be for gas very much. Probably worse if the gas has ethanol in it.
Best practice would be not to get oil or gas on your wiring.
Old 07-16-2016, 09:39 PM   #19
1project2many
Self-vulcanizing repair tape (Wikipedia calls it "Self Amalgamating" )is fuel resistant but spendy and doen't really look original.
https://www.amazon.com/dp/B002LA2258?psc=1
Old 07-16-2016, 09:55 PM   #20
Paulski
http://www.mcmaster.com/#standard-ca...eving/=13bbqp9
Paulski is offline   Reply With Quote
Old 07-16-2016, 11:11 PM   #21
DransportGarage
DransportGarage's Avatar
Originally Posted by Paulski View Post
Welcome, Paulski! This is the first time I've seen someone's first 2 posts be a helping hand to other members. Awesome!!
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Thread Tools
Display Modes
