Old 11-26-2014, 09:48 PM   #1
D.Brown
Fuel gauge not working.
I have a 1985 k10 that had the dual tanks but someone took the p.s side tank out. How do i go about fixing the fuel gauge?
D.Brown is offline   Reply With Quote
Old 11-26-2014, 10:30 PM   #2
swissarmychainsaw
Re: Fuel gauge not working.
There is a factory switch near the ashtray? If it's factory, the switch will change for each tank .
Did you check the fuse? Has it ever worked or is this a new to you project?
swissarmychainsaw is offline   Reply With Quote
Old 11-26-2014, 10:37 PM   #3
D.Brown
Yeah this a new project. I forgot all about there being a switch for a tank, first truck that suppose to have dual tanks. The switch is missing though.
Old 11-27-2014, 12:02 AM   #4
D.Brown
I found what was left of the switch behind where it was supposed to be. The face plate is missing to it.
Old 11-27-2014, 12:28 AM   #5
D.Brown
Still don't know why the fuel gauge doesn't work though.
Old 11-27-2014, 12:56 PM   #6
Oregoon
Roadside Rebuilder
Oregoon's Avatar
Mine's all over the place, too. I think it's a grounding issue, since it works properly at times. I have a single tank though.
I'll use a dipstick and the odometer until I figure it out.
Oregoon is offline   Reply With Quote
Old 11-27-2014, 04:04 PM   #7
hatzie
Moderator
hatzie's Avatar
1981-1991 dual tanks have the fuel sender wires routed through a switch inside the tank valve. The only function of the dash switch in 1985 is to run the valve shuttle motor left or right. If the valve is missing and the wiring is butchered you'll have to splice the fuel gauge wire to the LH tank sender wire.
If the wiring is still down there and reasonably complete... but not the valve. Or the valve is not properly switching the gauge. And. You have no intention to refit/repair the missing tank and missing/damaged valve immediately you can fit a single wire jumper plug to make up for the missing/damaged tank valve. That way you can fit the missing tank and valve later, when you want it, without kicking yourself for chopping up a perfectly good cab-to-valve harness.
You'll need the following Delphi Packard parts;
1, Weatherpack Shroud 6 Contact Body Delphi Part # 12010975
2, Weatherpack Terminal 16-14AWG Male Delphi Part # 12124582
2, Weatherpack Cable Seal Green Delphi Part # 15324982
4, Weatherpack Cavity Plugs Delphi Part # 12010300
8" of SXL jacketed 16AWG wire
Wipe some Sil Glyde on the cavity seals and the cable seals.
Make up the short wire shunt...
  1. Push the wire into the seals with the narrow ends facing the cut ends of the wire and the fat ends toward the center then push them back 2-3".
  2. Strip around 3/16" of the wire jacket and pull the seals back down toward the end so the narrow ends come up even with the cut end of the jacket.
  3. Put the terminal in your Weatherpack crimp tool and push the wire in till the shoulder on the seal hits the strain relief ears on the terminal making sure that all the wire strands will be crimped inside the terminal.
The connector cavities are lettered A-F
Insert the Weatherpack wire loop you just made into C (LH Sender) and B (Fuel Gauge) till you hear a click in each socket.
Then put the four cavity plugs in A, & D-F to keep crud salt etc out of the other terminals.
Flip the strain relief cover over and snap it down on the tail of the new connector you just made.
Plugging this new connector in will route C LH tank sender to B the fuel gauge wire just as if the valve were present and working.
This is the detail at the valve...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Thread Tools
Display Modes
