Old 11-26-2014, 10:50 PM   #1
MidwestMan
MidwestMan's Avatar
One thing after another.... Truck just shut off.
Never ends it seems, fix one thing then something else F's up.
Was driving about 30 down the road then it just shut off as if I turned the ignition off. Whole lotta cranking and nothing, tried on and off for ten minutes or so then decided I better check and see if I can hear the fuel pump.
Fuel pump was working so I tried it one more time.... Fired right up but then the blinkers and brake lights wouldn't work. Ran fine heading home, would the module in the dizzy cause some crap like this??
87 TBI 350.
MidwestMan is offline   Reply With Quote
Old 11-27-2014, 10:12 AM   #2
tlawre87
tlawre87's Avatar
Re: One thing after another.... Truck just shut off.
Battery and all those connections in good shape? The way you said it just cut off almost sounds like a ground issue.
Trevor
74 C20...work in progress.
04 Saturn Ion...Daily Driver
tlawre87 is offline   Reply With Quote
Old 11-27-2014, 11:48 AM   #3
Just call me Sean
Just call me Sean's Avatar
I would check the fusible links and junction block.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 11-27-2014, 12:23 PM   #4
MidwestMan
MidwestMan's Avatar
Battery ground is good, just checked it. Fired right up but blinkers still don't work.
Thread Tools
Display Modes
