Old 11-30-2014, 10:09 PM   #1
Jackrabbit760
66 c20 rear end swap
Hello all, my name is Brian. I'm new member but not new to the site as I have been lurking around sponging up info. Gotta say its a neat site with bunch of good members to learn from. I own a 66 c20 long bed fleetside. It's powered by a small block 327 and it's a 4 speed (granny). I have an eaton rear end can't say what gear ratio it has but I know that I'm on 4th gear doing 45 maybe 50 tops and the rpms are roaring. I'm in need for a rear end swap since that would be the easier swap than a tranny swap. I recently picked up a dana 60 with 354 gear ratio from a 72 chevy at the local junkyard. I will be picking up a kit from a local shop that consists of the new perches and adjustable trac bar possible new u bolts, not really sure. I have a few questions before I tackle the job. First questions is where do I began lol what would be first before removing the eaton rear end?? Measure, record pinon angle on the eaton rear end or is it a pretty straight forward?? Any how here ate some pictures, what kind of thread would this be with out any pictures. Thank you all for looking and can't wait to hear some replies
Jackrabbit760 is offline   Reply With Quote
Old 11-30-2014, 10:27 PM   #2
Jackrabbit760
Re: 66 c20 rear end swap
Old 11-30-2014, 10:28 PM   #3
Jackrabbit760
Sorry guys, don't know why it's not allowing me to upload multiple images
Old 12-01-2014, 02:06 AM   #4
Captainfab
60-66 Nut
Welcome to the forum
Here is a thread with some good details on how it should be done. The thread is on installing a 14 bolt, but the procedure is the same for your Dana 60. I believe there is a link in that thread to the one LostMy65 made on his 14 bolt conversion. Too bad you didn't find a Dana 60 from a coil spring/trailing arm suspension.
BTW backing plate to backing plate is not the correct way to measure a differential width. You should be measuring WMS to WMS (Wheel Mounting Surface). The location of the backing plate will change depending on the size of the brakes. The wheel mounting surface is what matters since that is what determines where the tires will be.
Old 12-01-2014, 01:17 PM   #5
Jackrabbit760
Thank you sir, I will know for a future reference
Thread Tools
Display Modes
