08-19-2003, 12:37 AM | #1 |
headlight upgrades
built truck from ground up now needing headlights thought about upgrading post pictures of new styles with part numbers thanks scott
08-20-2003, 12:10 PM | #2 |
Who said that?
sorry i cant help, but i am interested in the same thing.
08-20-2003, 12:20 PM | #3 |
This is an old post I saved you may want to look through this one. I dont remember what all was in there. Go here
Good luck Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
08-20-2003, 05:12 PM | #4 |
My other Love
you could go and buy the H4 conversion kit from bosch and even go wilder and get the H.I.D conversion for your h4's.
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
08-20-2003, 08:02 PM | #5 |
Headlight Conversion
I put the following lights on my 67: http://cgi.ebay.com/ebaymotors/ws/eB...tem=2423465992
I am still working on cleaning up the bezels (previous owner painted them white) but the lights look great. They are really a bright white and have a small bulb that is at the bottom on the light. I wired the small light up to my parking lights, so they come on at the same time. The ring around the bulb glows for about 20 mins after I turn off the lights. You could even change out the small bulb for a different color or put in a strobe if you wanted. They have a flat surface which I really like. I got them to fit with only a small modification. I can take a picture of them if anybody wants to see them, but realize there is no bezel there only because they have been removed to be cleaned.
67 C20 LWB 454 BB THD 400 97 Jeep Wrangler 4cyl 5sp |
08-20-2003, 09:18 PM | #6 |
These look cool! Haven't tried them yet but they should work well.
http://www.matrixracing.com/browse_i...p?Item_ID=4366
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
08-20-2003, 09:43 PM | #7 |
PROJECT 7DEUCE
I bought mid 80's motorcycle flatface headlight's with a replacable halogen bulb.. Work killer!!
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-20-2003, 09:56 PM | #8 | |
Where's my beer?
Re: Headlight Conversion
Paul How do you make the invisible, visible?.........You take it away. |
08-21-2003, 08:52 AM | #9 |
Will take a picture when I get home and post it.
08-21-2003, 10:17 AM | #10 |
14.1 @ 96MPH
I think I'm going to do the relay-mod to my GMC soon, since the relay-mod to my A/C worked so well...once I got a real crimper, that is
Question...does anyone know of any other good points to tap high-current 12V, aside from the fender post? I think I'm starting to get quite a bit of stuff off of that little wire...
Project1970 - LS1 Swap Complete! |
08-21-2003, 10:21 AM | #11 |
Out of the carpool lane.
What about the horn relay? Isn't there a 12V source off that?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
08-21-2003, 10:46 AM | #12 |
Project 1970, what did a relay do for your a/c?
08-21-2003, 11:30 AM | #13 |
14.1 @ 96MPH
I was having major problems with burning up the fan control switch - one a year, if not more. And my high-speed setting was disconnected, as the factory wiring for that was toast and kept trying to light up!!!
Simple solution - two relays and a DPDT switch. (All this to replace the functionality of my entire A/C panel!!! Hehe.) Switch left turns on both relays, which both puts the fan on HIGH (14V to the fan does that) and engages the A/C compressor clutch. To the right only engages the fan relay, while leaving the A/C relay off. I think for the headlights, I'll just put a big ring-terminal on the end and go right from the battery cable...
08-21-2003, 11:37 AM | #14 |
MOVE OVER
ttt
No matter where you are..... There you are... Buckaroo Banzi |
08-21-2003, 07:55 PM | #15 |
Headlight Upgrades
Ok, here are a couple of pics of the headlights.
08-21-2003, 07:56 PM | #16 |
Headlight Upgrades
Here is another one, this is my low beams.
08-21-2003, 07:57 PM | #17 |
Headlight Upgrade
This is my parking lights, you can see that there is a light glow from the small lights that are mounted inside the headlights.
08-21-2003, 08:01 PM | #18 |
Where's my beer?
Cool padreisla, Gracias for the pics, and what was that modification you did to your new headlights to make them fit?
08-21-2003, 08:10 PM | #19 |
Headlight Upgrade
Where the small bulb is connected in the back bottom area, the socket sticks out too far. So I took my drill and drilled out a hole the size of the socket. That way if and when I want to change out the bulb it will be easier to get to it. I am attaching picture of back of headlight so you can see where I am talking about the bottom bulb.
08-21-2003, 10:05 PM | #20 |
My other Love
what is the point of the bottom bulb?
08-21-2003, 11:24 PM | #21 |
Headlight Upgrade
I am going to paint the truck blue and will install a blue bulb in the headlight to give off a blue tint. Mostly for car shows and so on, it is illegal here to have blue lights on your vehicle. But I already have a set of blue neons for under it, and have blue neons that wrap around the 6X9 speakers in the door. So really it is just consmetic for me. Heck I just wanted flat light bulbs and they were there so I bought them......impulse buying I guess.
08-22-2003, 09:06 AM | #22 |
huh?
Those lights are awesome padreisla, I think I'm going to buy a set! Thanks for the pics and the ebay link!!!
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
08-22-2003, 12:18 PM | #23 |
Where's my beer?
Thanks for the info padreisla, I think I'm going to get me a set as well.
08-22-2003, 04:31 PM | #24 |
Informative lighting sites:
http://lighting.mbz.org/home.html http://www.team.net/sol/tech/light-up.html Last edited by jimfulco; 08-22-2003 at 04:52 PM. |
01-15-2004, 11:27 AM | #25 |
Can't kick the addiction!
Who makes the lights in the pics? I need to get a set.
Thread Tools | |
Display Modes | |
