Old 12-22-2014, 06:43 PM   #1
joecarquest
joecarquest's Avatar
Stales and won't start
I have a 1966 custom camper 327 with points and trubo 400 trans. This wire is loose i replace the vacuum advance and the screw is striped and the ground wire will not stay tight. So dwell 28 degrees and 8 degrees before top dead center. i got the engine running fine drove a block staled and would not start
joecarquest is offline   Reply With Quote
Old 12-22-2014, 08:50 PM   #2
pimpston65
pimpston65's Avatar
Re: Stales and won't start
no sparky no starty
pimpston65 is offline   Reply With Quote
Old 12-22-2014, 09:20 PM   #3
joecarquest
so that means yes
Old 12-23-2014, 02:54 AM   #4
pimpston65
pimpston65's Avatar
not sure what the question is, but if you lose ground to the dizzy the engine will die and wont restart. fix the ground to clean unrusted metal and cross your fingers...
Old 12-23-2014, 11:30 AM   #5
geezer#99
geezer#99's Avatar
Do you have some better pics of your 327 Joe?
Your distributor and a couple other things don't look right.
geezer#99 is online now   Reply With Quote
Old 12-23-2014, 05:50 PM   #6
joecarquest
just found the picture of the wire on line
I think its for a v8 jeep.
But that is the wire I am having a problem with
Old 12-23-2014, 06:22 PM   #7
geezer#99
geezer#99's Avatar
Cheater!! LOL!!
Use a self tapping screw in place of that one.
Old 12-24-2014, 02:35 PM   #8
joecarquest
thanks for the help everybody
Thread Tools
Display Modes
