12-25-2014, 03:22 PM | #1 |
Led Bulbs
I just got some 1157 led bulbs and went to install. i have had alot of problems making them twist and lock into the sockets. Have anyone else tried these bulbs and did you have any issues getting these into the sockets? I have broken two of them off at the base. Any suggestions or ideas?
12-25-2014, 04:58 PM | #2 |
Old member
Re: Led Bulbs
Are you talking about these? I ended up throwing them in the trash. I never could get them to work correctly.
12-25-2014, 05:05 PM | #3 |
Re: Led Bulbs
Not like those. smaller with alot more leds. They work fine once you finally get them in the socket. found them on ebay. They just dont want to twist into the socket. What you using on the big red now?
12-25-2014, 06:50 PM | #4 |
Old member
Re: Led Bulbs
I have the real LED panels in the back and front parking lights. I have the side markers LED too.
12-25-2014, 08:57 PM | #5 |
Re: Led Bulbs
I have had this problem on motorcycles. The problem is, you're bottoming out on the flared part before it's low enough to lock in (at least that's what I figured out after trial and error)!
72 C10 - Multicolor, 4.8 ls, NV3500. Sold 72 K5 - Under Construction |
12-25-2014, 10:32 PM | #6 |
Re: Led Bulbs
I'll give Tommy's Truck Parts a call about those panels. They probby have an outlet for them.
12-25-2014, 10:33 PM | #7 |
Re: Led Bulbs
I'm gonna try working on the contacts on the bottom and try the bottoming out thought! Thanks
12-26-2014, 09:01 AM | #8 | |
Old member
Re: Led Bulbs
Link for you. http://67-72chevytrucks.com/vboard/s....php?p=5393945
Thread Tools | |
Display Modes | |
