Old 01-02-2015, 03:57 AM   #1
87Skier
87Skier's Avatar
Taking oil pan off with engine in truck
So I know this may be a little hard to directly answer because not every truck/engine combo is the same. So, I recently swapped a new motor into my Jimmy and it is leaking a lot of oil from the front of the engine. I can't tell exactly where it is coming from, but it is dripping from the lowest point where the oil pan and timing cover meet.
When I say a lot, I mean I may drive it about 30 or 40 miles and it loses almost a quart. The engine is a 1997 Vortec 350 motor, and while I had it out I put all new seals on, a new timing set and timing cover (not supposed to reuse the old one according to GM), but I ended up buying a cheaper aftermarket one and I think this is where my problem is coming from. The oil pan gasket is a 1 piece FelPro gasket.
So, my plan is to replace the timing cover (with a Dorman OE replacement), oil pan gasket, front main seal, and timing cover gaskets. Can this be done in the truck? Or does the motor need to come back out.
Also, should I be looking elsewhere for leaks?
Thanks!
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 01-02-2015, 04:34 AM   #2
scottybaccus
scottybaccus's Avatar
Re: Taking oil pan off with engine in truck
You won't need an oil pan gasket unless it's damaged. Timing covers are problematic. You should be able to remove it by just lossening the pan bolts, leaving the two at the rear lightly snug, and remove a few toward the front. This will let the front of the pan droop enough to work.
It may be necessary to raise the motor up and block it in place for more room at the cross-member.
Plan on the new cover, new water pump gaskets, timing cover gaskets, and front seal. Use a shop vac to draw out any shavings while cleaning gasket surfaces so they don't all wind up in the pan. Also, there should be two dowel pins in the block for the timing cover. They were molded pins in the OE plastic cover, but you would need steel pins in the block for the aftermarket cover. If those were missing, that was your issue. Check the dorman cover. It could be made either way. You MUST have alignment pins of some kind. Make sure you use a new front seal, and lube it before install.
Scotty Baccus
scottybaccus is offline   Reply With Quote
Old 01-02-2015, 04:37 AM   #3
scottybaccus
Remove the oil dipstick while the pan is loose.
Scotty Baccus
Old 01-02-2015, 05:27 AM   #4
BlackedOut67shorty
BlackedOut67shorty's Avatar
I've done it but I had to take both motor mount bolts off and pick the engine up a lil with a cherry picker.
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 01-02-2015, 01:01 PM   #5
87Skier
87Skier's Avatar
I'm really beginning to think that it would be a lot easier to just pull the engine. I think I could have the engine out in less than 3 hours. Any reason not to?
Thanks for reminding me about the water pump gaskets. I think I have a few laying around.
Old 01-02-2015, 02:24 PM   #6
dell72
I replaced the pan gasket on my 72 K-20 in the truck. I supported the engine with a cherry picker and pulled the crossmember under the engine to gain access.
dell72 is offline   Reply With Quote
Old 01-02-2015, 05:17 PM   #7
franken
I had a similar situation w/ a 2nd gen Camaro. I think it was a groove worn in the balancer so I pulled the radiator, accessories, water pump, timing cover, motor mount bolts, the dist. cap, lifted the engine a bit and rotated the crank.
A speedy sleeve took care of the groove. I replaced the pan gasket just in case as well as all the other gaskets on stuff removed.
No more leaks.
I'd say it's easier not to remove the engine.
franken is offline   Reply With Quote
Old 01-06-2015, 02:03 AM   #8
87Skier
87Skier's Avatar
Well, I ended up pulling the engine. Even though I spent about 8 hours doing all the work, I'm happy that it doesn't leak anymore. Well worth the effort.
Old 01-06-2015, 11:28 AM   #9
67 chevelle
67 chevelle's Avatar
Most of the time when it leaks that much its the front seal ,, pull the balancer and replace
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 01-06-2015, 06:01 PM   #10
Guy Dudebro
I changed the oil pan and timing chain gasket very recently. I unbolted the engine from the frame and used a jack to raise the engine and transmission up for access. I put the jack on the flywheel and it remained steady. It was a bioatch to change the oil pan gasket though. Use the fel pro snap gaskets for sure. Even with those, it's still a tight fit.
Guy Dudebro is offline   Reply With Quote
Thread Tools
Display Modes
